3 Pages123>
#1 Posted : Wednesday, July 31, 2013 7:17:47 AM(UTC)
vMix 10 is finally here!
Please report any bugs or issues in this thread.
If no issues are reported this version will be made available on the main web site in a couple of days.
Download
http://cdn.vmix.com.au/download/vmix10.exe
Changes
Interface
New improved Input Settings window with built-in Preview
Input Settings MultiView supports custom presets
MultiView elements can be dragged around within Input Settings Preview
Video
Two independed outputs. 1. Fullscreen 2. External, Streaming and Recording
Outputs can be set to either Output, Preview, MultiView or an Input
RTSP renamed to Stream with support for Transport Streams (Teradek Sputnik) and additional IP cameras
Image Sequence now uses up to 10x less memory
Image Input will dynamically check for updates to the source image
All video clip inputs are now synchronised with the global frame rate
New "Double Box" or MultiView templates added to Virtual Sets
Audio
Audio Channel Selection (Mono, Left, Right, All)
Audio Gain (0 to 24db boost)
Recording
MP4 Support (H264 Video + AAC Audio)
Additional codec support for 64bit including GoPro CineForm
External Output / Streaming
Separate resolutions for External and Virtual Capture / Streaming
vMix Video and vMix Audio devices can now be used in 3rd party programs even if vMix is not running
Advanced button added to Streaming with additional options such as AAC support (when AAC support has been added to FMLE)
Titles
Live button added to title editor. When de-activated text changes will be previewed only
Countdown timer supports displaying up to 99 minutes when in minute:seconds format
Overlays
Stingers can be configured as "Stinger 1" and "Stinger 2" on any transition button
Stingers are now frame accurate, with frame cut point toggle in Overlay settings
Overlays can now be previewed by right clicking the 1,2,3,4 buttons
Other
Performance improvements across the board
Updated PlayList manager, it is now easier to switch between different preset playlists
Many more API options available including GUID support
Added API functions for Deinterlace, Sharpen, Mirror, Picture Transitions, Alpha, Volume and more
MultiCorder supports selecting different folders for each camera
Many bug fixes and general improvements
thanks 4 users thanked admin for this useful post.
sontoloyo on 7/31/2013(UTC), atpt on 7/31/2013(UTC), Damn2Good4U on 7/31/2013(UTC), Adriankey4 on 8/30/2013(UTC)
melody
#2 Posted : Wednesday, July 31, 2013 1:12:05 PM(UTC)
Rank: Guest
Groups: Guests
hi martin,
i noticed something strange with this new v10.0.0.55, when import an mp4 recorded in vmix, sliding forward, the audio metter is not showing correct levels, however mp4 works well in vmix.
regards,
melody
www.espiritosanto.cc
Henny
#3 Posted : Wednesday, July 31, 2013 6:16:02 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Hi
I see you have the ability to select which outputs the overlays show on working, but is there any way to enable a choice of which output is shown and program out in the right of the interface, I'm thinking on using the the full screen out to feed on set in vision plasma screens with overlay 1&2 on main output (external and rec) and 3&4 on fullscreen, with the idea being I can have a safe graphic for the plasmas on overlay 3 and start a VT on overlay 4 before cutting to it in the main mix, then come out of the video on the mix before the plasmas etc also use it to do remote interviews with the remote guest on the plasma and still able to cut to them full screen.
the problem is the program shows the full screen and not the rec/ext so i can't see what I'm doing on the main mix when i have anything on the overlay of the fullscreen
cheers
dodgepong
#4 Posted : Thursday, August 1, 2013 10:36:16 AM(UTC)
dodgepong
Whenever I go to install vMix over the previous version, I get an error saying that it can't overwrite vMixVideo.ax. The program isn't running, and rebooting doesn't seem to help. Any ideas on what's going on?
dundurs
#5 Posted : Thursday, August 1, 2013 10:44:55 AM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
close skype
thanks 1 user thanked dundurs for this useful post.
dodgepong on 8/1/2013(UTC)
dodgepong
#6 Posted : Thursday, August 1, 2013 10:48:37 AM(UTC)
dodgepong
dundurs wrote:
close skype
Wow, thank you! That worked!
...why on earth did that work?
dundurs
#7 Posted : Thursday, August 1, 2013 10:50:21 AM(UTC)
dundurs
dodgepong wrote:
dundurs wrote:
close skype
I guess skype uses vMix virtual video device
dodgepong
#8 Posted : Thursday, August 1, 2013 10:52:42 AM(UTC)
dodgepong
Right, that makes sense. It must have loaded the vMix directshow output as a potential webcam, even though it's not using it.
jet
#9 Posted : Thursday, August 1, 2013 2:01:43 PM(UTC)
jet
Was thanked: 39 time(s) in 37 post(s)
Hi Martin!
Found out that putting W7 to Sleep while vMix 10.0.0.55 with some video inputs active will crash vMix after wake up.
vMix says something about unhandled exception.
Kind regards,
J. Tervo
dundurs
#10 Posted : Thursday, August 1, 2013 2:07:18 PM(UTC)
dundurs
Hi Martin!
Kind regards,
J. Tervo
I think you've got to be reasonable. To ask for as complicated software as vMix, which uses a lot of 3rd party software (drivers, codecs) to be stable and work after sleep/hibernation is not realistic.
MrFreeze
#11 Posted : Friday, August 2, 2013 10:20:16 AM(UTC)
MrFreeze
dundurs wrote:
Hi Martin!
Kind regards,
J. Tervo
Agreed,
Why are you putting your computer to sleep while vmix is still running away?
#12 Posted : Friday, August 2, 2013 11:22:21 AM(UTC)
I would be interested in seeing the full message just so I know if it is an issue external to vMix or not (drivers etc)
PFBM
#13 Posted : Friday, August 2, 2013 3:52:19 PM(UTC)
PFBM
Hi Martin.
Is it possible to record audio on the video files in 24 bit stereo ? besides the existing 16 bit ?
most cards like blackmagic intersity pro have 24 bit capability on the audio converters.
Best regards,
PFBM
Greg
#14 Posted : Tuesday, August 6, 2013 9:35:20 AM(UTC)
Greg
Is the version 10 file made to update the older version 9 or do I need to uninstall version 9 before installing version 10? I think I have installed all other updates without uninstalling the older versions.
Greg
#15 Posted : Tuesday, August 6, 2013 9:49:11 AM(UTC)
Hi Greg,
You can install over the top of vMix 9.
Greg on 8/6/2013(UTC)
Greg
#16 Posted : Tuesday, August 6, 2013 10:18:23 AM(UTC)
Greg
Thanks for the quick reply, I know it is late there. Also thank you for all the work you have done with the program it just keeps getting better and better. Keep up the good work.
Greg
Greg
#17 Posted : Tuesday, August 6, 2013 11:41:05 AM(UTC)
Greg
Looking through the new layout I notice that some of the settings on the input settings or options screen are cut off and don't allow you to see them all to adjust or set them. My screen resolution is set to 1920x1080. I know it is probably a setting somewhere that I need to change. What are your suggestions. I tried to insert a image to show what it looks like but the insert image only inserts [img][/img]and doesn't give me a option to select a picture.
Greg
Henny
#18 Posted : Tuesday, August 6, 2013 4:41:28 PM(UTC)
Henny
i'm getting same issue with settings screens
UserPostedImageClick to View
thanks 1 user thanked Henny for this useful post.
Greg
#19 Posted : Tuesday, August 6, 2013 4:55:45 PM(UTC)
Greg
Henny
That is what I am getting when I go to the settings screen.
I am using the Nvidia Quadro 1000M video card and the Lenovo program says I have the latest driver.
I also switched to my Intel HD Graphics 3000 onboard video and it looks the same way.
Greg
#20 Posted : Wednesday, August 7, 2013 9:26:03 AM(UTC)
Hi Greg,
Looks like you might have the scaling in windows set to something other than 100%.
Control Panel -> Appearance and Personalization -> Make text and other items larger or smaller
vMix works best in 100%
That said, I will put up a small update shortly that should help in some situations.
Greg on 8/7/2013(UTC)
3 Pages123>
