Systems
New high-end machine
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi everyone
I'm looking at a new high end streaming machine. Looking at having it built. Something along the obsidian line of things. Hoping to get some tips!
- How do people make sure the PC is safe for travelling to events? Especially so the graphics card doesn't put too much pressure on the motherboard with small bumps? - Does anyone know of a rack mount case that supports the graphic card securely, rather than the pcie slot only? - What's the best i9 compatible motherboard that has thunderbolt 3? - Can someone please explain the 4K SDI and HDMI capture cards... is there a card that can do 4 x 4K inputs/outputs simultaneously?
Thanks heaps!
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
This is how I built my setup. 1) Added additional supports (non-metallic, hot glued to Case and not Motherboard) under the motherboard. 2) Hot glued Ram holding clips. 3) PCI-E Cards are held in place by mounting screws, and at backend by support bar provided by case manufacturer in case. 4) Hot Glued PCI-E cards and any cables coming from Motherboard and on Case Also for extra security. After over 100 Pro Hockey Games over 2 years, and traveling across North America by Bus and Vehicles, still no issues. 1 Compact 4U Rackmount Case. 1 Rolling 4U Rolling Case. 2 manufacturers of capture cards Blackmagicdesign HDMI 4 x 4K60 NONE SDI 4 x 4K60 https://www.blackmagicdesign.com/products/decklink/techspecs/W-DLK-31SDI 8 x 4K60 https://www.blackmagicdesign.com/products/decklink/techspecs/W-DLK-30SDI 4 x 8K60 https://www.blackmagicdesign.com/products/decklink/techspecs/W-DLK-34Yuan HDMI 4 x 4K30 https://www.yuan.com.tw/products/capture/4k/sc560n4_hdmi.htmSDI 4 x 4K30 https://www.yuan.com.tw/products/capture/4k/sc560n4_sdi_6g.htmMotherboards I'm using in my next i9 build.. https://www.gigabyte.com/Motherboard/X299-DESIGNARE-EX-rev-10#kfwaldron18 wrote:Hi everyone
Thanks heaps! desmar attached the following image(s):  11-148-058-02.jpg (14kb) downloaded 13 time(s). GRR-4PL-US_1_FF.jpg (325kb) downloaded 16 time(s).You cannot view/download attachments. Try to login or register.
 1 user thanked desmar for this useful post.
Thanks Desmar... that's very helpful! I'd be keen to try an get it in a 3U case. Do you know any? Also, would you be happy to share a photo of how you supported your GPU? Thanks heaps
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Rackmount Cases need to have front and rear facing fans, as any other locations not a good solution, will still get some overheating issues in warm conditions. For custom case hardware. TCH Reliable Hardware
Systems
