How to create vMix Title & Animated Title in Microsoft Blend for Visual Studio 2017
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
 9 users thanked desmar for this useful post.
Joined: 3/6/2018(UTC) Posts: 11  Location: Quiapo, Manila Thanks: 87 times Was thanked: 1 time(s) in 1 post(s)
Joined: 2/18/2018(UTC) Posts: 28  Location: Milan, Italy Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
Thank you very much, I was looking for a tutorial to use Blend.
Now my question: what about creating a "squeezed title"? Is it possible to do with Blend for VS2017? For example, if I create a textbox but when I change the text in vMix the text is longer than the textbox and I don't want to create a new line is it possible to squeeze the text but without changing the height of the text?
Matteo
 1 user thanked matteoarrigone for this useful post.
Yes, you can. matteoarrigone wrote:Thank you very much, I was looking for a tutorial to use Blend.
Matteo
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
Thanks for your tutorial, wanted to get into Blend for a while.
I've been using CasparCG with image sequences with and wanted to import the same image sequences into Blend, but I couldn't figure out how I can import an image sequence. Is that even possible?
I would like to create animations with something like After Effects and then just add the image sequence as a background and animate the titles.
I just got back getting into writing software after 30-year hiatus.. lol I have only been playing with Blend and Visual Studio for 6 months now. So much has changed and so much to learn yet, but enjoying the challenge. Not sure about image sequences, I tried implementing playing a media element but did not work in vMix, will try in the next couple of days to see if it works. Rinsky wrote:Thanks for your tutorial, wanted to get into Blend for a while.
 1 user thanked desmar for this useful post.
Great, thank you! Looking forward to it!
And maybe you can also tell me if it's possible to create a stop action for animations at a certain point or maybe a loop between the in and out transition.
