desmar
#1 Posted : Friday, June 1, 2018 11:12:52 PM(UTC)
desmar
Canada
How to create
vMix Title & Animated Title in Microsoft Blend for Visual Studio 2017
Project attached
File Attachment(s):
vMixTitleDemo.zip (259kb) downloaded 140 time(s).
thanks 9 users thanked desmar for this useful post.
mburel1980 on 6/2/2018(UTC), rowby on 6/2/2018(UTC), Peter B on 6/3/2018(UTC), QuiapoChurch on 6/5/2018(UTC), matteoarrigone on 6/5/2018(UTC), vijay6672 on 6/5/2018(UTC), monamiga on 6/8/2018(UTC), Rinsky on 6/9/2018(UTC), raugert on 7/28/2018(UTC)
#2 Posted : Saturday, June 2, 2018 3:56:49 AM(UTC)
Thanks Marc !
QuiapoChurch
#3 Posted : Tuesday, June 5, 2018 6:21:32 AM(UTC)
QuiapoChurch
Philippines
Thank you Sir!
matteoarrigone
#4 Posted : Tuesday, June 5, 2018 9:56:58 AM(UTC)
matteoarrigone
Thank you very much, I was looking for a tutorial to use Blend.
Now my question: what about creating a "squeezed title"? Is it possible to do with Blend for VS2017? For example, if I create a textbox but when I change the text in vMix the text is longer than the textbox and I don't want to create a new line is it possible to squeeze the text but without changing the height of the text?
Matteo
thanks 1 user thanked matteoarrigone for this useful post.
desmar
#5 Posted : Tuesday, June 5, 2018 6:00:23 PM(UTC)
desmar
Canada
Yes, you can.
Matteo
Rinsky
#6 Posted : Friday, June 8, 2018 3:59:30 PM(UTC)
Rinsky
Thanks for your tutorial, wanted to get into Blend for a while.
I've been using CasparCG with image sequences with and wanted to import the same image sequences into Blend, but I couldn't figure out how I can import an image sequence. Is that even possible?
I would like to create animations with something like After Effects and then just add the image sequence as a background and animate the titles.
desmar
#7 Posted : Friday, June 8, 2018 9:02:38 PM(UTC)
desmar
Canada
I just got back getting into writing software after 30-year hiatus.. lol
I have only been playing with Blend and Visual Studio for 6 months now.
So much has changed and so much to learn yet, but enjoying the challenge.
Not sure about image sequences, I tried implementing playing a media element but did not work in vMix, will try in the next couple of days to see if it works.
thanks 1 user thanked desmar for this useful post.
Rinsky
#8 Posted : Saturday, June 9, 2018 7:32:12 PM(UTC)
Rinsky
Great, thank you! Looking forward to it!
And maybe you can also tell me if it's possible to create a stop action for animations at a certain point or maybe a loop between the in and out transition.
Guest (4)
