Joined: 5/14/2013(UTC) Posts: 153  Location: uk Thanks: 2 times Was thanked: 27 time(s) in 23 post(s)
Hi All, I'm Currently Building a small studio install and rather than using on air lights ect i'm going with a INFO screen system, threw out the studio/gallery/green room ect i'm installing a number of 15" Vga TFT's, The idea for theses are to display things like current production name,Current Time,Studio Status ect. I'm Codeing this display in VVVV and by querying Vmix's Api for: Recording Status Streaming Status current active input current active input Type Duration of active Video Position of active Video On the displays if the Studio is streaming and or Recording the Background of the Display is RED and Recording and or Streaming is Displayed in the top corner The Current Production name is displayed and can be edited from a webpage from any pc on the LAN. If a video is playing and Active on output a countdown of the time remaining on the video is shown at the bottom of the display (this currently only works for the main output i need to add a bit of code to check if a video is playing in an overlay) The next stage is to put some design into the look of the display, Currently I've Just thrown in the elements and not put any time in to the style or look of it. once i have tidied things up I will share the VVVV patch but below is how it currently looks,  Cheers Ian
Hi Henny,
I seem not to really get what you are trying to do here... Could you please expatiate further?
Will the info screen be showing on an external lcd or where?
Sorry if this sound a lame question... i only just want to get it all right.
regards, Rottimmy
Hi
Yes this will run on a separate pc feeding a number of external displays.
The idea is rather than having a number of clocks and OnAir lights around the studio and surrounding areas we use TFT computer monitors all split from one pc
We will also mount one below the 42" plasma we use on the studio floor so the presenters know how long is left on a video clip, displays will also be installed in the galllery for the director to reference off and in the sound control room
Joined: 11/14/2012(UTC) Posts: 319  Location: Finland Thanks: 203 times Was thanked: 19 time(s) in 17 post(s)
Henny wrote:Hi All, I'm Currently Building a small studio install and rather than using on air lights ect i'm going with a INFO screen system, threw out the studio/gallery/green room ect i'm installing a number of 15" Vga TFT's, The idea for theses are to display things like current production name,Current Time,Studio Status ect. Ian Nice work! I would have use for this in our studio. Kind regards, J. Tervo
Video mixed with vMix (studio portions). Turn subtitles / CC on:
Henny wrote:Hi
We will also mount one below the 42" plasma we use on the studio floor so the presenters know how long is left on a video clip, displays will also be installed in the galllery for the director to reference off and in the sound control room Nice work! This is a must have...
Very nice idea! I'm looking forward to your software.
I'd love to have some further features on the info screen. Basically it is all about a "Countdown-Timer" I'm used to look at in typical production studios. The countdown should ideally be customizable with the following options:
- Countdown to next half-hour (time left) - Countdown to next full-hour (time left) - Countdown from a start time set by user (time left for a flexible period) - Count Up since "Record", "Ext Output" or a new event was triggered by the user interaction ("Start Counter Button"?) was started
It would be nice to indicate on screen, which counter is in use at the moment (sth. like "half" / "full" / "user" and "trigger", "record", “tape”, “duration” or “OnAir” for the last value).
Finally.... although I like the idea of a separate Screen or Tablet showing these Figures, but shouldn’t we talk about the integration of such a Feature on the new MultiScreen???
