MSVCR100.dll error occurs when the external output is used by another video recorder
I am on testing vMix, and I met an error when the vMix external output is used as a input by another video recorder programs. I've tested several recorder programs, and found that same error is occurred on all those programs.
The error is like below;
Unhandled exception occured[0xC0000005@0x78AA1ED7] at MSVCR100.dll Additional exception informatin has been stored locally and this application will be terminated.
- vMix version: latest one. - OS: Windows XP 32bit
Is there any clue to resolve this problem?
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
What settings do you have configured in vMix under the External Output tab? Also, what happens when trying to use the vMix Video device while vMix isn't running?
Thanks for the reply.
==> External Output tab settings --------------------------------- vMix video device: checked DeckLink Renderer: unchecked System: NTSC 59.94i or 29.97p Output size: 720x576 ...... (not editable) Audio delay: 0
That's all. Nothing is modified.
==> What happens when trying to use the vMix Video device while vMix isn't running? The video device is working well when directly used by the another video recorder program.
