Joined: 9/4/2011(UTC) Posts: 15  Location: South Africa Was thanked: 2 time(s) in 2 post(s)
Hi Martin
A suggestion I would like to make on future releases, and just about all that is still needed in vMix.That is the function to select al the wipes, mixes, zoom transition effect]ect. to the T bar/slider that can only crossfade between two sources at the moment. It would be a handy tool to have, as sometimes we like to do a horizontal wipe and keep the two inputs on the screen simultaneously. That would also mean adding a horizontal wipe to the list of transitions. We have purchased a license for vMix and is using it in a live broadcast of corporate productions.
Thank you very much Barend
 1 user thanked barend for this useful post.
Joined: 6/11/2012(UTC) Posts: 41  Location: jakarta Thanks: 35 times Was thanked: 12 time(s) in 7 post(s)
barend wrote:Hi Martin
A suggestion I would like to make on future releases, and just about all that is still needed in vMix.That is the function to select al the wipes, mixes, zoom transition effect]ect. to the T bar/slider that can only crossfade between two sources at the moment. Maybe this post can help to manually transition http://forums.vmix.com.au/default.aspx?g=posts&m=2904#post2904
Thank you very much Barend Check the answer below as quoted by Martin about a year ago..martin wrote:The Manual Transition uses whatever the first button is configured as (the one after Cut). So change this to change the manual effect.
Martin vMix
 1 user thanked Damn2Good4U for this useful post.
Thank you for the info . I would like to have a horizontal wipe added to the transitions please
