barend
#1 Posted : Saturday, July 20, 2013 2:05:02 PM(UTC)
barend
Hi Martin
A suggestion I would like to make on future releases, and just about all that is still needed in vMix.That is the function to select al the wipes, mixes, zoom transition effect]ect. to the T bar/slider that can only crossfade between two sources at the moment. It would be a handy tool to have, as sometimes we like to do a horizontal wipe and keep the two inputs on the screen simultaneously. That would also mean adding a horizontal wipe to the list of transitions. We have purchased a license for vMix and is using it in a live broadcast of corporate productions.
Thank you very much
Barend
thanks 1 user thanked barend for this useful post.
Adriankey4 on 8/17/2013(UTC)
kayllastudio
#2 Posted : Saturday, July 20, 2013 9:57:47 PM(UTC)
kayllastudio
Was thanked: 12 time(s) in 7 post(s)
barend wrote:
Hi Martin
Maybe this post can help to manually transition
http://forums.vmix.com.au/default.aspx?g=posts&m=2904#post2904
Damn2Good4U
#3 Posted : Sunday, July 21, 2013 7:28:18 AM(UTC)
Damn2Good4U
barend wrote:
Hi Martin
Thank you very much
Barend
Check the answer below as quoted by Martin about a year ago..
martin wrote:
The Manual Transition uses whatever the first button is configured as (the one after Cut). So change this to change the manual effect.
thanks 1 user thanked Damn2Good4U for this useful post.
barend
#4 Posted : Sunday, July 21, 2013 3:14:09 PM(UTC)
barend
Thank you for the info . I would like to have a horizontal wipe added to the transitions please
