3 Pages<123>
richardgatarski
#21 Posted : Friday, May 25, 2018 2:44:18 PM(UTC)
richardgatarski
* Added "Custom Multi-Bitrate" dropdown option in streaming destinations.
This allows custom URLs and Stream Keys for each stream without using separate streaming instances for each which may cause problems with some CDNs
Where is this option? Looked for it but can't find it.
Earlier today using 21.0.0.41 and trying to stream to two separate Custom RTMPs, using the same streaming settings including "Hardware encoder" checkbox on, I got an error message when I started the second stream when the first was running. Something like the graphics card had not enough resource to do hardware encoding. Changed second stream to not use hardware encoding, which worked. Updated to 21.0.0.42 and now it works fine streaming when both has hardware encoding on.
imagebotique
#22 Posted : Friday, May 25, 2018 5:40:59 PM(UTC)
imagebotique
on Vmix 21.0.0.42
When adding a Photos input and pointing to a folder on my desktop containing 27 .jpg and .png image files the input shows up as if it contains 54 inputs or exactly double the actual 27 files in the folder (these are 27 uniquely different images and file names). e.g. 21/54 35/54 which shows up under the preview and program windows. The first 27 inputs flip back and forth between the first and second image in the folder then the remaining 27 images or the second half of the slide show play normally as they should. The input should only show 27 files as that is the number of files in the folder.
Henny
#23 Posted : Friday, May 25, 2018 5:43:46 PM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
We’re the files copied from a Mac ?? In Windows explorer Set it to show hidden files and you will see a load of Mac preview files that can be deleted
thanks 1 user thanked Henny for this useful post.
imagebotique on 5/25/2018(UTC)
imagebotique
#24 Posted : Friday, May 25, 2018 6:05:35 PM(UTC)
imagebotique
NOT A BUG, just a weird Mac thing.
such a simple fix but not so apparent if you don't know what your looking for.
Thanks for the great software Martin. I own 8 licenses and love it.
chrisis
#25 Posted : Friday, May 25, 2018 7:59:09 PM(UTC)
chrisis
desmar wrote:
From the vMix 21 User's Manual
Key and Fill output support-External Output
chrisis wrote:
Is there a guide somewhere for setting up key/fill output?
It is worth noting that this functionality only works with Black Magic Desktop Video 10.10. I was on 10.9 and the alpha channel was not being output. Might be worth adding the minimum requirement to the guide.
Mari
#26 Posted : Saturday, May 26, 2018 9:51:41 AM(UTC)
Mari
Netherlands
Just updated to 21.0.0.42.
Now I get a "Warning: GPU Overloaded" message on the bottom of the screen, didn't have this error with previous version (20.x.x.x).
When I switch from Nvidia GTX960M to the build in Intel 530 the error is gone...
Any solution/setting I can check to get rid of this warning?
Mari attached the following image(s):
#27 Posted : Saturday, May 26, 2018 11:01:01 AM(UTC)
See below for some information on the warning:
https://www.vmix.com/kno...ge-at-the-bottom-of-vmix
Mari
#28 Posted : Saturday, May 26, 2018 12:44:23 PM(UTC)
Mari
Netherlands
... have read the information... problem has been solved by installing the latest NVidia-driver (which was released yesterday... No notification about update so I missed this one)...
matt
#29 Posted : Tuesday, May 29, 2018 3:26:15 PM(UTC)
matt
21.0.0.41 Works great, no issues with my workflow - Thank you.
upgrade to 21.0.0.42
issue:
If there is no camera input signal on a active SDI input, the statistics window / source dropped column now shows 60 dropped frame per second and counting.
with all previous versions, it would show "o" dropped frames. Anyone else notice? Is this a bug or new feature?
Decklink quad2 - same issues with BM driver 10.9.5 and 10.10
windows 10 - updated
Nvidia driver - updated
corporatejames
#30 Posted : Tuesday, May 29, 2018 8:07:54 PM(UTC)
corporatejames
issue:
I have noticed that on SDI/Camera inputs that don't have camera connected show dropped frames, this should be zero if not connected.
thanks 1 user thanked corporatejames for this useful post.
niemi on 5/30/2018(UTC)
#31 Posted : Tuesday, May 29, 2018 10:21:48 PM(UTC)
Yes, this is actually a bug fix.
With Blackmagic drivers, it would report receiving a frame even if there was no signal connected.
Now it does not, which is more accurate and useful for diagnosing no signal issues.
corporatejames on 5/30/2018(UTC), kgoodyer on 6/13/2018(UTC)
PrepSpin
#32 Posted : Saturday, June 2, 2018 4:37:32 PM(UTC)
PrepSpin
Was thanked: 16 time(s) in 11 post(s)
I am seeing dropped frames as well on Blackmagic Design cards when there is no camera signal. I have BMD driver 10.10 and vMix 21.0.0.44 installed.
#33 Posted : Saturday, June 2, 2018 8:56:50 PM(UTC)
Correct, this is by design.
PrepSpin on 6/3/2018(UTC)
PrepSpin
#34 Posted : Wednesday, June 13, 2018 12:08:48 AM(UTC)
PrepSpin
Anyone having vMix crash when clicking on the gear icon next to record? This has been happening to us frequently in vMix 21. We set the drive to not sleep but when we click on that gear icon vMix just crashes. If we simply hit record and not the gear icon it records like normal.
Cpilcher
#35 Posted : Wednesday, June 13, 2018 12:14:11 AM(UTC)
Cpilcher
I have not seen this happen on my install of 21. Does it do it with a blank preset?
#36 Posted : Wednesday, June 13, 2018 1:29:54 AM(UTC)
Sounds like a bad codec. To find out the cause:
1. Right click the Start Menu and select Event Viewer
2. From the left hand panel, open Windows Logs and then click on Application
3. From the list, find the entry for "Application Error" that mentions vMix64.exe in the description when clicking on it.
4. In the description it will note the .dll file of the codec causing the issue.
PrepSpin on 6/14/2018(UTC)
corporatejames
#37 Posted : Wednesday, June 13, 2018 1:36:56 AM(UTC)
corporatejames
I have had that issue in previous versions if go to make a change by clicking on the cog wheel after say about 5 - 10mins of having a large preset open. If I need to make a change to recording name for example and click the cog wheel vmix can crash. when I first open Vmix it is fine so have been doing that as first thing to do after opening preset. Clicking recording is always ok. But this is random
so have been able to pin point why and doesn't seem to be a widely reported problem that I'm aware of and has improved with updates. Martin may be able to help. Probably conflicting with something and have had the issue on my laptop and pc.
PrepSpin
#38 Posted : Friday, June 15, 2018 6:36:35 PM(UTC)
PrepSpin
Here is what the error says:
Faulting application name: vMix64.exe, version: 21.0.0.45, time stamp: 0x5b1e08b5
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00000000219f6d20
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report Id: %13
Faulting package full name: %14
Faulting package-relative application ID: %15
Also this
Fault bucket 1163875182637357230, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: vMix64.exe
P2: 21.0.0.45
P3: 5b1e08b5
P4: unknown
P5: 0.0.0.0
P6: 00000000
P7: c0000005
P8: 00000000219f6d20
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERDE74.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERDE85.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERDE93.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERDEA4.tmp.txt
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vMix64.exe_6ea2b1f096aeec6e577f83ea8a7c957b511fb3f_00000000_2670e431
Analysis symbol:
Rechecking for solution: 0
Report Id: 0fe73911-1556-47ea-bb7e-b2c6e94a671e
Report Status: 268435456
Hashed bucket: 85c0cabfb82fca746026ea4fe7fe18ae
Cab Guid: 0
Joeboe
#39 Posted : Friday, June 15, 2018 7:38:20 PM(UTC)
Joeboe
I can not remember getting such in any of my installs, but what I get, is drop frames before record...when I click on 'Record', I get sometimes 7 frames, sometimes 1 sometimes as much as 30 frames dropped....if I stop and start again, most times I do not get any drop frames, but since I updated, I find that if I stop recording after a good session, when I restart, I get endless dropped frames, in clusters of 10, 15, even as much as 33 frames at a time, and I am forced to restart vMix...this will happen often, sometimes I have to do a reboot of the system to get a good recording...and this is only since I upgraded to ver. 21.....never happened before, yes, I would get a 1 frame sometimes, and I credited that to the HD, as I use a laptop, and those drives do not spin very fast....but this high drop frames since upgrade, is killing me...
#40 Posted : Saturday, June 16, 2018 1:11:48 AM(UTC)
PrepSpin,
Might be best to drop us an email to info@vmix.com.au for some further investigation.
It is quite strange, as we have not made any changes to the recording feature since vMix 20
PrepSpin on 6/16/2018(UTC)
Guest (10)
3 Pages<123>
