RaMaS
#1 Posted : Tuesday, May 22, 2018 4:26:45 PM(UTC)
RaMaS
How to fix this error? Windows 10 Pro Version 10.0.17134 Build 17134
https://youtu.be/6vrZYBkmy4E
corporatejames
#2 Posted : Wednesday, May 23, 2018 5:31:51 AM(UTC)
corporatejames
GO to Windows settings > Privacy > Microphone > Allow Apps to access Microphone (this should be set to ON)
This change occurred in a recent Windows update. Martin may be able get around the need for that as I thought was only for Web Apps
like Browsers and Store Apps
thanks 1 user thanked corporatejames for this useful post.
Ario on 5/23/2018(UTC)
jammerxd
#3 Posted : Wednesday, May 30, 2018 10:35:43 AM(UTC)
jammerxd
4K user here, I had to do the same thing, thanks for the solution! Hope they get it fixed soon, also, with the latest windows update, ALL of my sound settings got reset. I use virtual audio cable and windows decided it would be a good idea to reset all the bitrates. Fun fun fun, gotta love windows!
