codinlab
#1 Posted : Saturday, May 19, 2018 6:52:38 AM(UTC)
codinlab
vMix version : 21.0.0.41
I want to use multi-bitrate streaming with Akamai CDN.
Akamai requires streamnames formated like this : [eventname]_[angle]_[bitrate]@[entrypoint id] (ie: myevent_1_1500@12345, myevent_1_800@12345, myevent_1_500@12345)
Documentation says : "If your stream provider has given you a separate stream key for each stream, then configure these streams by selecting Custom Multi-Bitrate as the Destination dropdown and type in the separate URL and Stream Key for each stream."
But I'm unable to find "Custom Multi-Bitrate" in destination dropdown. Is it a documentation mistake ("Custom Multi-Bitrate" instead of "Custom RTMP Server") or an issue in my installation ?
I tested duplicate "Custom RTMP Server" for my 3 streams, but Akamai's entrypoint rejects stream 2 & 3 connections.
When using "Stream 1 Multi-Bitrate" as destination, vMix appends a stream index at the end of stream name, what is not suitable in my case.
Could you please consider allowing character replacement in streamnames when using "Stream 1 Multi-Bitrate" destination ? (like "%v", "%b" and "%i" in FMLE)
SportsNetUSA.net
#2 Posted : Saturday, May 19, 2018 3:28:58 PM(UTC)
SportsNetUSA.net
Did you try stream names such as this?
myevent_1_1@12345
myevent_1_2@12345
myevent_1_3@12345
#3 Posted : Tuesday, May 22, 2018 1:43:31 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
codinlab,
The documentation was from the future and mentioned a feature not yet released, sorry about that!
The good news is this dropdown option now exists in vMix 21.0.0.42 which has just been released.
ThomasK
#4 Posted : Wednesday, September 5, 2018 3:39:50 PM(UTC)
ThomasK
Austria
Hi Admin,
it seems that the option is again missing in vMix 21.0.0.55. There is no Custom Multi-Bitrate option:
ThomasK attached the following image(s):
ThomasK
#5 Posted : Wednesday, September 5, 2018 3:46:09 PM(UTC)
ThomasK
Austria
God it, its only available if stream 1 is configured, then for stream 2 and stream 3 "Custom Multi-Bitrate" is available.
Should get updated here: https://www.vmix.com/hel...tm?StreamingQuality.html
