Custom Multi-Bitrate streaming
vMix version : 21.0.0.41 I want to use multi-bitrate streaming with Akamai CDN. Akamai requires streamnames formated like this : [eventname]_[angle]_[bitrate]@[entrypoint id] (ie: myevent_1_1500@12345, myevent_1_800@12345, myevent_1_500@12345) Documentation says : "If your stream provider has given you a separate stream key for each stream, then configure these streams by selecting Custom Multi-Bitrate as the Destination dropdown and type in the separate URL and Stream Key for each stream." But I'm unable to find "Custom Multi-Bitrate" in destination dropdown. Is it a documentation mistake ("Custom Multi-Bitrate" instead of "Custom RTMP Server") or an issue in my installation ? I tested duplicate "Custom RTMP Server" for my 3 streams, but Akamai's entrypoint rejects stream 2 & 3 connections. When using "Stream 1 Multi-Bitrate" as destination, vMix appends a stream index at the end of stream name, what is not suitable in my case. Could you please consider allowing character replacement in streamnames when using "Stream 1 Multi-Bitrate" destination ? (like "%v", "%b" and "%i" in FMLE)
Quote:Akamai requires streamnames formated like this : [eventname]_[angle]_[bitrate]@[entrypoint id] (ie: myevent_1_1500@12345, myevent_1_800@12345, myevent_1_500@12345) Did you try stream names such as this? myevent_1_1@12345 myevent_1_2@12345 myevent_1_3@12345
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
codinlab,
The documentation was from the future and mentioned a feature not yet released, sorry about that! The good news is this dropdown option now exists in vMix 21.0.0.42 which has just been released.
Joined: 8/11/2018(UTC) Posts: 60   Thanks: 33 times Was thanked: 6 time(s) in 6 post(s)
Hi Admin, it seems that the option is again missing in vMix 21.0.0.55. There is no Custom Multi-Bitrate option: ThomasK attached the following image(s):  vMix64_2018-09-04_21-39-16.png (17kb) downloaded 6 time(s).You cannot view/download attachments. Try to login or register.
