Multi-Bitrate Trial 21.0.0.41 x64
Joined: 5/17/2018(UTC) Posts: 9 Location: Washington State
When I installed the latest version, I am no longer able to stream using multi-bitrate.
The first stream works, but the successive two won't log onto the server. Wonder if I'm the only one with a problem. The previous version worked fine.
Hi, How are the streams configured in vMix? In most cases it should be "Stream 1 Multi-Bitrate" selected from the 2 and 3 destination dropdown menus. Then selecting a different quality for each one. If you are still seeing issues, send a support report from Settings -> About in vMix then drop us an email to info@vmix.com.auRegards, Martin vMix
I did as you suggested. I sent in the error report and emailed support. Thanks a ton!
Jeff
Martin, I decided to see if I could roll back the version and found I was reinstalling the Trial version. But!!! The multi-bitrate is now working. Go figure.
Not sure what the issue was, but even without changing any settings, it just works. Yea!
Thanks again for your quick reply. Just knowing there is help is amazing to me. ;)
Hi Jeff,
As your provider has different streaming keys for each stream, go through each tab and double check the URL and Stream Key exactly match that particular stream and make sure the destinations are set to Custom RTMP Server.
According to the logs, the error is due to an incorrect stream key or password.
Martin vMix
