4 Pages«<234
#61 Posted : Tuesday, May 8, 2018 8:45:29 AM(UTC)
PiotrSzmidt wrote:
Cant set alpha cannel on any of the device now. SEnding only straigh FILL on both devices
Correct, the Mini Monitor does not support Key and Fill.
See the documentation below:
https://www.vmix.com/help21/KeyFill.html
PiotrSzmidt
#62 Posted : Tuesday, May 8, 2018 9:12:49 AM(UTC)
PiotrSzmidt
ok, but i want to use 1st Mini Monitor to send Fill, and 2nd Minimonitor to send key. In this case i assume thats not possilbe?
PrepSpin
#63 Posted : Tuesday, May 8, 2018 11:25:27 PM(UTC)
PrepSpin
Was thanked: 16 time(s) in 11 post(s)
I keep getting a D3DERR_INVALIDCALL Error Message and vMix crashes afterwards on vMix 21. Says Invalid Call and gives this number 2005530516
#64 Posted : Tuesday, May 8, 2018 11:29:06 PM(UTC)
This is caused by some software on the laptop interfering with the graphics.
Look for ASUS Sonic Suite 2 or ASUS Sonic Radar and uninstall these.
PrepSpin on 5/8/2018(UTC), avsoundguy on 5/9/2018(UTC)
PrepSpin
#65 Posted : Tuesday, May 8, 2018 11:49:31 PM(UTC)
PrepSpin
You are a GENIUS! That worked Martin! Thank you....
thanks 1 user thanked PrepSpin for this useful post.
Kaf
#66 Posted : Thursday, May 10, 2018 8:44:44 AM(UTC)
Kaf
Already reported but :
- vMix Call create audio drops when your framerate is 59/60 fps (at least no audio drops when the project run with 30Fps)
- VLC Stream sources is bottom cropped when you play RTMP (you lost a few lines)
- No VLC Stream API for "Addinput" (only FLASH / VIDEO / IMAGE etc...)
Keep up the good work :)
niemi
#67 Posted : Sunday, May 13, 2018 3:04:41 AM(UTC)
niemi
Was thanked: 19 time(s) in 16 post(s)
If these issues could be fixed it v21 would be very appreciated too.
Blackmagic Decklink Duo 2 and Quad 2 input anomalies in vMix:
- After a while (typically several hours) input will turn black requiring a vMix source refresh before input will show on the Decklink input.*
- When using a Sonnet Echo Express SE III enclosure with a Duo 2 an input in vMix can turn black and stay unusable. Current fix is to close vMix, unplug thunderbolt cable and plug it in again opening vMix again. A reboot will also fix the unusable input.**
*Seen on Desktop Video firmware 10.9.7 - 10.9.11. Seen on Decklink Duo 2 and Quad 2 installed in a custom build Z87 system running vMix 20.0.55 and a ASUS GL502VM with Sonnet Echo Express SE III running vMix vMix 21.0.0.39 beta.
**Seen on Desktop Video firmware 10.9.11 on Decklink Duo 2 installed in a Sonnet Echo Express SE III running vMix 20.0.55.
ovinas
#68 Posted : Sunday, May 13, 2018 4:34:08 AM(UTC)
ovinas
@niemi
First thing for you to do would be to use the current BMD drivers 10.9.12
Second thing would be to confirm it's a vMix problem. Did you try that with some other apps like OBS?
#69 Posted : Sunday, May 13, 2018 4:57:01 AM(UTC)
vMix 21.0.0.40 beta has been uploaded!
http://cdn.vmix.com/download/vmix21preview.exe
Changes/Fixes:
* NewBlue NDI command support increased to 10 layers.
* Installer will now disable ASUS Sonic Suite 2 if it is installed as it can cause a number of graphics issues.
* Will now check for media components not installed under Windows 10 N and will prompt the user to install the Media Feature Pack.
* Fixed a slow memory leak with some title templates.
* Added streaming quality presets for Facebook.
* Fixed PSF detection issue with AJA devices.
* Fixed some other minor memory leaks
thanks 7 users thanked admin for this useful post.
stigaard on 5/13/2018(UTC), ask on 5/13/2018(UTC), BETech on 5/13/2018(UTC), corporatejames on 5/13/2018(UTC), PrepSpin on 5/14/2018(UTC), monamiga on 5/15/2018(UTC), dedlinemedia on 11/10/2018(UTC)
marcyaghi1
#70 Posted : Monday, May 14, 2018 8:28:01 AM(UTC)
marcyaghi1
Afganistan
WMIX 21 GPU OVERLOAD WARNING , NOT HAPPENING IN V 20 , please check
#71 Posted : Monday, May 14, 2018 10:57:16 AM(UTC)
This is by design. vMix will now alert the user if they are using too many GPU resources.
The following Knowledge Base article goes over some things to check:
https://www.vmix.com/kno...nosing-high-render-times
Ario on 5/15/2018(UTC)
PrepSpin
#72 Posted: : Monday, May 14, 2018 12:06:03 PM(UTC)
PrepSpin
I put vMix 21.0.0.40 beta through a MiLB Baseball game last night where we streamed, recorded, 3 camera replays,External output, and many graphics and it was flawless. All on the same system. Over 3 hours without a dropped frame on the recording. All in 1080P 60. Great job Martin and Tim!
thanks 5 users thanked PrepSpin for this useful post.
ON.tv Channels on 5/14/2018(UTC), corporatejames on 5/15/2018(UTC), Ario on 5/15/2018(UTC), SHMD on 5/15/2018(UTC), rowby on 5/16/2018(UTC)
monamiga
#73 Posted : Tuesday, May 15, 2018 12:55:42 AM(UTC)
monamiga
Philippines
Finally BMD HD Mini Key/Fill now works with vMix 21.0.0.40 beta.
monamiga attached the following image(s):
thanks 2 users thanked monamiga for this useful post.
corporatejames on 5/15/2018(UTC), rowby on 5/16/2018(UTC)
niemi
#74 Posted : Tuesday, May 15, 2018 10:46:16 AM(UTC)
niemi
vMix 21.0.0.40 beta issue:
- Unplugging Blackmagic Decklink Duo 2, installed in a Sonnet Echo Express SE III and connected via Thunderbolt 3, leaves the Decklink Duo 2 sources in an unrecoverable state after reconnecting the capture card. You will have to close vMix and open it again to use the inputs again.
OBS 21.1.0 and Blackmagic Media Express 3.5.5 both handle unplugging and reconnecting very well and do not need to be restarted.
Tested on:
- ASUS GL502VM
- Dell Alienware 13 R3
Drivers:
- Desktop Video 10.9.12
- Intel Thunderbolt 17.3.73.350
ovinas
#75 Posted : Tuesday, May 15, 2018 3:32:01 PM(UTC)
ovinas
Can't add audio inputs on two different systems anymore. vMix is 21.0.0.40 on Windows 10 1803. I don't know how long the problem already exists. Error window says "Access denied". Error reports sent.
corporatejames
#76 Posted : Tuesday, May 15, 2018 7:29:11 PM(UTC)
corporatejames
Go to Privacy Settings in Windows and go to Microphone and set allow apps to use Microphone (this enables Vmix to be able to use devices that are using the default Windows drivers)
I don't have issue if using the devices own device driver. I noticed this on the weekend when I pulled out a old device to test something and couldn't add local microphone or that device but
behringer UMC404HD was fine. I think this was caused by recent Windows 10 update with security and I thought it was only related to web applications that use audio.
Same issue was for v20 as well so not related to v21 as my Asus laptop didn't have v21 installed yet as use that for production.
thanks 1 user thanked corporatejames for this useful post.
ovinas
#77 Posted : Wednesday, May 16, 2018 12:38:59 AM(UTC)
ovinas
Yep, that did the trick, thanks. I also think that these settings never had any effect on vMix. But Windows is a bit like Facebook streaming: Worked yesterday, not so sure about today.....
thanks 1 user thanked ovinas for this useful post.
corporatejames on 5/16/2018(UTC)
corporatejames
#78 Posted : Wednesday, May 16, 2018 3:02:05 AM(UTC)
corporatejames
Maybe that's something Martin can add in one of the updates that resolves the need to enable/disable it as assuming having it disabled is better security. I only thought of it after thinking wtf is not working :( Windows 10 is a pain.
Joeboe
#79 Posted : Wednesday, May 16, 2018 7:58:15 AM(UTC)
Joeboe
I only update when I have no choice....I am still on windows 8.1....no issues, and I do NOT update. If it is not broken, why crack it......
#80 Posted : Thursday, May 17, 2018 2:06:58 AM(UTC)
vMix 21 has been officially released.
You can continue the discussion here:
https://forums.vmix.com/...ts&m=53473#post53473
Guest (10)
4 Pages«<234
