Hardware Compatibility
Magewell USB Capture 4k Plus - multichannel audio - how?
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Hi, How can I ingest 8 channels of audio using this device? It's only shows 2 channels of audio when adding Camera input (with SDI input option, not Line-in).
Check the Magewell documentation to know if it's supported by the device
Joined: 5/13/2014(UTC) Posts: 521   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
This is what the Magewell site says for the USB Capture 4K Plus (and the other similar USB Capture devices):
"Support for 2 channel IEC60958 audio streams"
The default Microsoft drivers used for these USB Plug&Play devices don't support more then 2 channels. For 8-channel audio capture (over HDMI or SDI) from a Magewell capture device you need the PCIe Pro Capture cards. Any of those will give you up to 8-ch audio into vMix (and other s/w which uses the Magewell SDK, e.g. NewTek Connect).
