Ernest Król
#1 Posted : Thursday, May 10, 2018 9:20:51 AM(UTC)
Ernest Król
How can I ingest 8 channels of audio using this device? It's only shows 2 channels of audio when adding Camera input (with SDI input option, not Line-in).
#2 Posted : Thursday, May 10, 2018 11:15:48 AM(UTC)
Check the Magewell documentation to know if it's supported by the device
zenvideo
#3 Posted : Thursday, May 10, 2018 3:41:03 PM(UTC)
zenvideo
This is what the Magewell site says for the USB Capture 4K Plus (and the other similar USB Capture devices):
"Support for 2 channel IEC60958 audio streams"
The default Microsoft drivers used for these USB Plug&Play devices don't support more then 2 channels. For 8-channel audio capture (over HDMI or SDI) from a Magewell capture device you need the PCIe Pro Capture cards. Any of those will give you up to 8-ch audio into vMix (and other s/w which uses the Magewell SDK, e.g. NewTek Connect).
