marcyaghi1
#1 Posted : Wednesday, May 9, 2018 1:16:08 AM(UTC)
marcyaghi1
Afganistan
hello
is it possible to make a transition on data-source change
lets say we have a lower-third with data-source , if we select another row from data-source then the text in the lower-third will change , can it change via transition ??
how that is possible
regards
#2 Posted : Wednesday, May 9, 2018 3:01:03 AM(UTC)
if you write your own utility in a title code
marcyaghi1
#3 Posted : Wednesday, May 9, 2018 6:05:53 AM(UTC)
marcyaghi1
Afganistan
yes is there an example ? please
#4 Posted : Wednesday, May 9, 2018 7:24:54 AM(UTC)
Depends on what you define as a transition in this case like title disapearing first and reapearing (overlay) with new info or while title is displayed the info being animated .
The First i am not aware of a title being able to have a transition(overlay) in the vMix sense triggered from within the same title so external app dealing with changes in data (and not use vMix datasources perse) and let that trigger the transition or in the latter case have some hidden textblocks (to catch a change first) related to your datasources trigger an animation before its displayed also in your "real" textblock
But if you had searched the forum ("title animation data change" for example) you would have found this has been asked before and i believe with demos on different approaches discussed
marcyaghi1
#5 Posted : Wednesday, May 9, 2018 11:05:44 AM(UTC)
marcyaghi1
Afganistan
sorry dear ,didn't find anything from what you said in search , could you please point me to it
regards
#6 Posted : Wednesday, May 9, 2018 12:55:51 PM(UTC)
regards
strange as when i search vMix forum on "title animation data change" i find topics like :
Data source trigger?
Dyamic XAML files
