-TA_
#1 Posted : Tuesday, May 8, 2018 1:39:20 PM(UTC)
-TA_
Any good guess how many NDI sources could i7 4770K + 750Ti handle properly ?
-Tommi
mjgraves
#2 Posted : Tuesday, May 8, 2018 2:06:13 PM(UTC)
mjgraves
Not a fan of guessing, but I have tried an experiment. I used NDI Tools and the Sienna test signal app to create 4 NDI sources. That's the limit of the utility computers I could draw into service.
My vMix system handled 4 - 1080p sources without issue. CPU around 15%
It's i7-5775C quad-core
16 GB Memory
GTX 750 Ti
Incidentally, I wish that the Newtek Test pattern generator has the ability to play a looping animation at a specified frame rate. The Sienna Test Signal Generator (OSX) does this. It's very handy to play a countdown leader known to be at 60p
#3 Posted : Tuesday, May 8, 2018 2:24:08 PM(UTC)
@ -TA_
NDI Sources are about a 5% hit per Source to CPU resources depending on the Source and your CPU.
The 4770K could probably handle 5 or 6 without issue as long as you don't have a lot of other demands on the CPU.
As always, you are best to test for yourself just how far you can push your system before you start having issues.
mjgraves on 5/23/2018(UTC)
