NDI
i7 4770K + 750Ti with NDI
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Any good guess how many NDI sources could i7 4770K + 750Ti handle properly ?
-Tommi
Not a fan of guessing, but I have tried an experiment. I used NDI Tools and the Sienna test signal app to create 4 NDI sources. That's the limit of the utility computers I could draw into service.
My vMix system handled 4 - 1080p sources without issue. CPU around 15%
It's i7-5775C quad-core 16 GB Memory GTX 750 Ti
Incidentally, I wish that the Newtek Test pattern generator has the ability to play a looping animation at a specified frame rate. The Sienna Test Signal Generator (OSX) does this. It's very handy to play a countdown leader known to be at 60p
@ -TA_
NDI Sources are about a 5% hit per Source to CPU resources depending on the Source and your CPU. The 4770K could probably handle 5 or 6 without issue as long as you don't have a lot of other demands on the CPU. As always, you are best to test for yourself just how far you can push your system before you start having issues.
NDI
