OBS can do Broadcast delay, means it records the output, but send it with some delay. Delay should be in seconds, and maximum should be like 20 minutes. (comming from this post: https://forums.vmix.com/...spx?g=posts&t=14521)Why? Because in some e-sport events the must is, to have a delay, as otherwise stream sniping could happen, means the enemy will know where you are from the broadcast you send (PUBG game). It is annoying that I have to use OBS for that events and not the for good money bought vMix.
Joined: 4/6/2017(UTC) Posts: 16  Location: Adelaide, SA Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Hey.
Go into the stream settings and then click the cog next to 'Quality'. This gives you a few more option to setting up the encoding settings including a 'network buffer' time which would act as a delay. Looks like it goes up to 2 minutes.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Just produce with vMix and send PGM to OBS to stream
