Reinaldo
#1 Posted : Friday, April 20, 2018 3:09:14 PM(UTC)
Reinaldo
Brazil
Hi guys, do you know any way to do audio fade more efficiently?
Picture below is my solution.
#2 Posted : Friday, April 20, 2018 5:30:29 PM(UTC)
If you have vMix Pro or 4K, you can do this with Scripts (a little loop and you're done)
vMix UTC is another option.
You can also do it manually more easily by using a Midi Controller with faders.
And I believe even with Shortcuts on a keyboard, there might be a way
Search the forum, I'm pretty sure this was addressed before.
Guillaume
Reinaldo on 4/24/2018(UTC)
cutter07
#3 Posted : Sunday, April 22, 2018 3:48:47 AM(UTC)
cutter07
You can add audio to multiview not only video, nice way to use autofade.
thanks 1 user thanked cutter07 for this useful post.
Barney Box Lane
#4 Posted : Sunday, April 22, 2018 9:10:19 AM(UTC)
Barney Box Lane
currently that's the way to do it, we use that method and in some cases where it it suits we use the multiview fade.
thanks 1 user thanked Barney Box Lane for this useful post.
Reinaldo
#5 Posted : Tuesday, April 24, 2018 6:13:19 PM(UTC)
Reinaldo
Brazil
Thanks, DWAM, cutter07 and Baney Box Lane.
