Joined: 5/24/2014(UTC) Posts: 46   Location: Brazil Thanks: 54 times Was thanked: 5 time(s) in 3 post(s)
Hi guys, do you know any way to do audio fade more efficiently? Picture below is my solution. Thanks
If you have vMix Pro or 4K, you can do this with Scripts (a little loop and you're done) vMix UTC is another option. You can also do it manually more easily by using a Midi Controller with faders. And I believe even with Shortcuts on a keyboard, there might be a way
Search the forum, I'm pretty sure this was addressed before.
Guillaume
Joined: 6/2/2012(UTC) Posts: 103  Location: Germany Thanks: 13 times Was thanked: 10 time(s) in 9 post(s)
You can add audio to multiview not only video, nice way to use autofade.
 1 user thanked cutter07 for this useful post.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
currently that's the way to do it, we use that method and in some cases where it it suits we use the multiview fade.
 1 user thanked Barney Box Lane for this useful post.
Thanks, DWAM, cutter07 and Baney Box Lane.
