abba2566
#1 Posted : Friday, April 20, 2018 8:58:24 AM(UTC)
abba2566
Has anyone had any luck getting the Datavideo HS-500 working with VMix? If so, what settings?
We're trying a SDI input using a Blackmagic Design DeckLink SDI 4K capture card.
If not, what's the best way of bringing multiple cameras into Vmix?
stevespaw
#2 Posted : Friday, April 20, 2018 9:43:04 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Sorry, but where to start? There is no SDI.
This HS-500 is a standard def Analog only device. You have a long way to go. You probably need more help that one forum post could do justice. Do you have local resources for help?
Steve
#3 Posted : Friday, April 20, 2018 9:51:18 AM(UTC)
Forget about the datavideo switcher, just buy a multi input capture card like the Blackmagic Decklink Duo 2 or equivalent by Magewell, Aja, Yuan and so on.
This way, you have multiple cams inputs into vMix itself.
Guillaume
stevespaw
#4 Posted : Friday, April 20, 2018 4:40:26 PM(UTC)
stevespaw
He probably only has composite video from his cameras, so that will be a bigger issue.
Steve
#5 Posted : Friday, April 20, 2018 5:21:12 PM(UTC)
Good point Steve! You may be right.
Yep trying to help with so little details is quite a challenge indeeed
h2video.nl
#6 Posted : Sunday, April 29, 2018 3:07:19 PM(UTC)
h2video.nl
I have one here, used to output to vmix for streaming and mix on the datavideo. the customer wants to see something with lights and buttons.
tried using it as a midi controller but the midi is only input.
so i guess, now woth hd towards 4k... there is not a lot of options left.
understand there are some countries that still use sd broadcast so will try and sell it. if you are interested, let me know!
stefan
