Anders
#1 Posted : Thursday, April 12, 2018 8:30:41 AM(UTC)
Anders
Was thanked: 10 time(s) in 7 post(s)
Is it possible to animate a picture in picture like in this video: https://youtu.be/vcDtbaAdVTc?t=2250
You can see it at 37:31 if the link didn't work.
Thanks!
#2 Posted : Thursday, April 12, 2018 8:49:21 AM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
Anders
#3 Posted : Thursday, April 12, 2018 9:00:58 AM(UTC)
Anders
Thanks, yes merge is what I use now. I just think the animated in from the side looks a bit slicker.
richardgatarski
#4 Posted : Thursday, April 12, 2018 9:48:43 AM(UTC)
richardgatarski
Then you have to use an Overlay and set its Effext to Slide.
#5 Posted : Thursday, April 12, 2018 10:11:36 AM(UTC)
Actually you can ;-) be it sliding in , zoom in/out etc
-create 2 (color) multiviews each with the 2 sources you want to "animate"
- one with layer 1 small and layer2 to large
- the other layer 1 larger and layer 2 smaler
basically one has a start situation and the other a finished one, merge between the 2
richardgatarski
#6 Posted : Thursday, April 12, 2018 10:50:24 AM(UTC)
richardgatarski
That's creativity Doggy!
#7 Posted : Thursday, April 12, 2018 10:57:44 AM(UTC)
thats vMix Richard ;-)
and add a few extra layers say a background and one with a logo or so that grow into view as well etc , that was fun to find out to basically completely copy (and more) the example Anders showed
Peter B
#8 Posted : Thursday, April 12, 2018 1:28:34 PM(UTC)
Peter B
In post #24 in this thread,
https://forums.vmix.com/...osts&t=11150&p=2
Martin suggested a new shortcut that would do audio fades.
The same shortcut type could be applied to set alpha, zoom, pan xy creating a keyframing system of sorts.
element
#9 Posted : Thursday, April 12, 2018 10:05:54 PM(UTC)
element
Just want to say, I've been using Doggy's style (sigh) for a good year+ now, and basically you can start doing some really cool things.
I always put all my initial sources into vmix and then make a collection of them for this use.
You can get around Vmix protection features to do some extra stuff too, like not always having both sources active and whatnot.
So if I have 3 main sources, I'll put the three in and then make a new source on top of a transparent .PNG
Then I'll do all sorts of transitions which slide in and out and even use the 3D tilt/pan and such.
By using the .PNG you can do a mass zoom all at once without having to do each manually.
Also, it's easier to size everything this way.
#10 Posted : Monday, March 25, 2019 4:20:56 AM(UTC)
it often happens when watching tv one wonders : can it be done in vMix :-)
Fun moment
thanks 3 users thanked doggy for this useful post.
stevespaw on 3/25/2019(UTC), sinc747 on 3/25/2019(UTC), Reinaldo on 3/27/2019(UTC)
