petervk
#1 Posted : Wednesday, April 11, 2018 2:04:10 PM(UTC)
petervk
I tried to install the RTW Loudness tools plugin.
Then it asked for my licence data and so I filled in.
I think I did not make a mistake as I copied the data from the clipboard, but the data was not accepted.
After that the attached error popped up saying that vMix was not able to initialize the plugin.
I tries again after reboot but vMix keep saying "able to initialize".
How can I reset and try again?
I sent my error report by the way.
petervk attached the following image(s):
ask
#2 Posted : Wednesday, April 11, 2018 7:50:23 PM(UTC)
ask
Quick check..is it a VST3 or VST2 plugin?
petervk
#3 Posted : Thursday, April 12, 2018 2:46:08 AM(UTC)
petervk
It's a VST3 plugin.
I know that vMix only supports VST3.
It's not that the plugin does not run at all.
It just broke after it did not accept my licence credentials.
Now I just want to start all over but re-installation did not help.
Thanks,
Peter.
petervk
#4 Posted : Sunday, April 22, 2018 5:05:23 AM(UTC)
petervk
Still getting that annoying "cannot initialize" error.
The stand alone loudness app works fine but just the plugin in vMix sucks.
Is there a way to cleanup plugin stuff in vMix?
Thanks,
Peter.
#5 Posted : Sunday, April 22, 2018 7:46:19 AM(UTC)
Contact this plugin editor support ! It's not a vMix issue you're having.
Did you check there is an un-installer ?
Guillaume
MrKneeland
#6 Posted : Tuesday, August 10, 2021 5:56:20 PM(UTC)
MrKneeland
I am having the exact same issue but with the Waves NS1 plugin. Other plugins from the Red suite work fine so it is not Vmix. I have also uninstalled and deleted all traces of the waves plugin on my C drive but I still can't make it work.
I have 2 users on the same PC could that be the issue?
MrKneeland
#7 Posted : Tuesday, August 10, 2021 7:25:29 PM(UTC)
MrKneeland
I have found the solution after digging a bit deeper into the dark corners of the internet.
This worked for me on the first try... make sure you log out from other accounts on the same laptop/pc
thanks 2 users thanked MrKneeland for this useful post.
ALTSoundandVisual on 8/12/2021(UTC), Cris_AV on 8/12/2021(UTC)
Cris_AV
#8 Posted : Thursday, August 12, 2021 10:32:19 PM(UTC)
Cris_AV
MrKneeland Man! you are an absolute legend. I had wasted the last 3 days of my life trying to find a solution for this issue. I surfed the whole internet, deep web and even I contacted Martin and nothing!. I was working in a show at home for 2 days and on show day vMix did not want to open my preset because of the issue with Waves plugins. Stress level 10 on a pretty simple show.
BTW I noticed the microsoft visual C++ packages was updated 4 days a go in my computer so again, is a windows update issue
I owe you a case of beers!
Thanks!
Cris
Guest (6)
