Separate audio compression on each stereo channel ???
Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Today when I switched on audio compression in the settings tab of an audio input source and I couldn't believe my ears. It looks like compression is applied on the left and right channel totally independent like if they were 2 mono channels. Unfortunately I cannot find a setting to change this unwanted behavior. One would expect this to be the "Channel" (All / SeparateMono) property but it isn't.
I use to work with 2 commentators for sports events. One is slightly panned to the left and one is panned to the right. When compression is applied and the left commentator speaks, depending on its sound level it looks like the panning changes from the left to the middle. This obviously is because compression is applied more to the left channel than to the right channel.
How can this be changed in a way that the level adjustment is done on both channels equally? And why on earth is this the default?
Thanks, Peter.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
 1 user thanked Peter B for this useful post.
Thanks Peter B. Are you saying that vMix is not putting any effort in audio processing anymore?
Peter
Thanks Peter. That makes sense.
