NDI
Microsoft Adding NDI Support To Skype
You have been a member since:: 3/7/2017(UTC) Posts: 60
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Just read on this Skype blog that a new version for content creators will be released that includes the ability to place and record calls with support for NDI. Has anyone played around with the preview version yet?
 1 user thanked sunkast for this useful post.
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
With Skype for Content Creators, Windows 10 and Mac users will be able to select the Content Creators mode to place and record calls directly within NDI®–enabled software such as: Wirecast Xsplit Vmix Read Article here for Skype for Content Creators
It certainly looks interesting, since Microsoft explicitly include vMix in their Skype blog post. I shall head to their booth at NAB at some point and take a look.
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Find out a few things if you can...
1. Will each caller be their own NDI feed? For multi-user calls? Or just one NDI feed (most likely). 2. Will it TAKE NDI as a camera & audio input.
Those are my biggest questions.
Joined: 12/10/2017(UTC) Posts: 96  Thanks: 13 times Was thanked: 15 time(s) in 13 post(s)
The biggest question that I would have would have to do with mix-minus audio.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everyone,
I am interested if desktop share and app share will be included, . Considering this is a new special version of Skype I would assume they would include all if the essential bells and whistles — and a way to deal with audio.
Great to see that vMix was included as an example — so someone at Skype is paying attention to what’s needed via NDI for programs like vMix.
Hopefully Skype will do it right — out of the box.
Roeby
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
jvphobic wrote:Find out a few things if you can...
Those are my biggest questions. >>> 2. Will it TAKE NDI as a camera & audio input. Apparently not, at least not in the first release. Of course in Windows NewTek has a free tool for emulating a webcam in the NDI v3.5 tools so this probably isn't such a problem. On Mac, it leaves a bit of a hole, although some NDI based tools like mimoLive can emulate a webcam
Those are my biggest questions. 1) Yes, as far as I can tell from a short chat on a noisy NAB booth, and without actually seeing a demo of any NDI connections, I believe an NDI source will be created for each caller, containing their video and audio. 2) As already mentioned, no, it does not (currently) accept an NDI feed as a local input. By implication, that also means it does not create mix-minus audio feeds to send to the caller(s). There should be a beta out in the next couple of months (probably), use of which will provide more accurate answers as to what it can and can't do, with regard to NDI.
 3 users thanked zenvideo for this useful post.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
does this basically mean we have an ndi bridge across networks now, so we don't have to just use it for a call with someone? or is not quite that level??
Barney Box Lane wrote:does this basically mean we have an ndi bridge across networks now, so we don't have to just use it for a call with someone? or is not quite that level?? No, it just means you can get an NDI output generated on your local PC, containing a clean feed of the incoming skype caller's video+audio, re-en-coded as an NDI source. So instead of having to screen-grab the skype display window, or capture the HDMI output of a graphics card in order to use the incoming video, you can get it into vMix as a NDI source. Skype itself still works in exactly the same way as before over the WAN.
NDI
