ELCHAPIN
#1 Posted : Tuesday, April 12, 2011 8:54:46 PM(UTC)
ELCHAPIN
Hey a new little problem
stream does not work ;
I am always connected to ustream, justin and livestream.
now appears only a black screen.
VIRTUAL VIMIX not recognized
check all settings,
I worked well on Windows XP.
now I use the Windows 7 64.
and delete and re-install several times Vmix 2011
and remains unchanged.
Sorry for the inconvenience
Siempre me conectaba a ustream , livestream y justin .
ahora aparece solo pantalla negra .
No reconoce el VIRTUAL VIMIX
revise todas las configuraciones ,
me trabajaba bien en WINDOWS XP .
ahora uso el WINDOWS 7 64 .
ya borre y re-Instale Vmix 2011 varias veces
y sigue igual .
siento por las molestias
+ Only con Adobe Flash
#2 Posted : Tuesday, April 12, 2011 9:04:09 PM(UTC)
Was thanked: 4677 time(s) in 1610 post(s)
Please provide some detailed information. Both of the provided screenshots do not show anything out of the ordinary.
ELCHAPIN
#3 Posted : Tuesday, April 12, 2011 9:15:44 PM(UTC)
ELCHAPIN
Hi Admin
yeah, I was translating the information
I never had this problem before
#4 Posted : Wednesday, April 13, 2011 12:21:55 AM(UTC)
Please run stream on FireFox or Google Chrome.
Or disabled Protected Mode in Internet Explorer (not recommended)
#5 Posted : Wednesday, April 13, 2011 12:48:32 AM(UTC)
Actually, it appears Chrome now runs in Protected Mode too so it will not work with vMix either.
The only workaround at the moment is to use FMLE or disable Protected Mode in Internet Explorer (which is not recommended)
As FMLE supports most of the streaming sites such as UStream, just use FMLE for the time being.
The next Beta should work with IE in Protected Mode under Windows 7.
ELCHAPIN
#6 Posted : Wednesday, April 13, 2011 1:26:59 AM(UTC)
ELCHAPIN
Download the New Procaster Livestream
does not work at first.
after 3 attempts I gave notice of VISTA AERO FOUND
accept - yes,
and works perfect with no errors but though only by Procaster Livestream.
Disconnect the AERO in 7 ml solution WIN!
I hope it helps for other friends
Testing forward
Descargue el Nuevo Procaster de Livestream
no trabaja al principio .
a los 3 Intentos me dio notificacion de VISTA AERO FOUND
acepte - yes-
y trabaja perfecto sin errores mas aunque solo en Livestream por Procaster .
Desconectar el AERO en WIN 7 mi solucion !
Espero sirva de ayuda para otros amigos
Seguiremos probando
ELCHAPIN
#7 Posted : Wednesday, April 13, 2011 1:41:27 AM(UTC)
ELCHAPIN
My problem were self
was corrected
Guest (4)
