Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hey a new little problem stream does not work ; I am always connected to ustream, justin and livestream. now appears only a black screen. VIRTUAL VIMIX not recognized check all settings, I worked well on Windows XP. now I use the Windows 7 64. ============================================ and delete and re-install several times Vmix 2011 and remains unchanged. Sorry for the inconvenience    Siempre me conectaba a ustream , livestream y justin . ahora aparece solo pantalla negra . No reconoce el VIRTUAL VIMIX revise todas las configuraciones , me trabajaba bien en WINDOWS XP . ahora uso el WINDOWS 7 64 . ======================================== ya borre y re-Instale Vmix 2011 varias veces y sigue igual . siento por las molestias + Only con Adobe Flash
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4788 time(s) in 1643 post(s)
Please provide some detailed information. Both of the provided screenshots do not show anything out of the ordinary.
Hi Admin yeah, I was translating the information I never had this problem before
Please run stream on FireFox or Google Chrome.
Or disabled Protected Mode in Internet Explorer (not recommended)
Actually, it appears Chrome now runs in Protected Mode too so it will not work with vMix either.
The only workaround at the moment is to use FMLE or disable Protected Mode in Internet Explorer (which is not recommended) As FMLE supports most of the streaming sites such as UStream, just use FMLE for the time being.
The next Beta should work with IE in Protected Mode under Windows 7.
Download the New Procaster Livestream does not work at first. after 3 attempts I gave notice of VISTA AERO FOUND accept - yes, and works perfect with no errors but though only by Procaster Livestream. ========================================= Disconnect the AERO in 7 ml solution WIN! I hope it helps for other friends
Testing forward  Descargue el Nuevo Procaster de Livestream no trabaja al principio . a los 3 Intentos me dio notificacion de VISTA AERO FOUND acepte - yes- y trabaja perfecto sin errores mas aunque solo en Livestream por Procaster . ========================================= Desconectar el AERO en WIN 7 mi solucion ! Espero sirva de ayuda para otros amigos Seguiremos probando
My problem were self was corrected Thanksadmin wrote:Please run stream on FireFox or Google Chrome.
