Feature Requests
Elgato Stream Deck support
Hi!
It would be great if this tool could also support the Elgato Stream Deck equipment.
Thanx
 1 user thanked kozaka for this useful post.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
just to check you've seen it, you know you can apply shortcuts in vmix to keyboard keys to carry out every function - then on the streamdeck you can apply hotkeys assigned to the keyboard buttons and it will work when vmix is the main window
 1 user thanked Barney Box Lane for this useful post.
Barney Box Lane wrote:just to check you've seen it, you know you can apply shortcuts in vmix to keyboard keys to carry out every function - then on the streamdeck you can apply hotkeys assigned to the keyboard buttons and it will work when vmix is the main window Sure this works, but I would like to have a real integration as other tools do, like Game Capture, Mixer, OBS Studio, Stream Labs, Twitch, Xsplit, youtube, etc.
kozaka wrote:Barney Box Lane wrote:just to check you've seen it, you know you can apply shortcuts in vmix to keyboard keys to carry out every function - then on the streamdeck you can apply hotkeys assigned to the keyboard buttons and it will work when vmix is the main window Sure this works, but I would like to have a real integration as other tools do, like Game Capture, Mixer, OBS Studio, Stream Labs, Twitch, Xsplit, youtube, etc. Here is a screen shot what I meant. This means "only" that Stream Deck should know and work together with vMix. kozaka attached the following image(s):  stream_deck.PNG (70kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Joined: 10/20/2016(UTC) Posts: 57 Location: Virginia-USA
Thanks: 5 times Was thanked: 6 time(s) in 4 post(s)
Until this feature is implemented to the extent you requested, the Web API Functions in vMix work perfectly in the Website button (click the Access in background checkbox)*. And you can create keyboard hotkeys in vMix that work perfectly with Hotkey Switch, and Hotkey buttons in the stream deck. Granted vMix will not detect directly pressed buttons, but it will work.
Not exactly what you are wanting, but still fully functional. It's what I use, however my streamdeck is on a different system than my vMix system, so I can't use any integrations with any applications.
Hope this helps
Jon
* = in the latest release of streamdeck's application, the "Access in background" is not functioning. A ticket has been opened, but if you use version 2.2.0.5165 it works just fine.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
kozaka wrote:Hi!
Thanx Maybe , maybe not as in preprogrammed options as it would be hard to incorporate all of vMix shortcuts so it's a good thing to know how to create your own buttons anyway as has been mentioned in how before (hotkey and/or website buttons) Have been using it for 4 days intensivly during a production , often reprogramming it on the fly and all went perfectly , be it i prefer the Website button over the Hotkey one for the simple fact that our vMix window isnt always the active one (or used from remote computer)
Feature Requests
