NDI
vMix and NDI: CPU vs GPU?
Hi all,
I'm looking into building a new system specifically for running vMix. We use 4 or more NDI inputs per shoot, and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment.
Thanks.
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
atmonauti wrote:... and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment. The NDI SDK uses the CPU for its codec, so i9 will probably be best.
Thanks: 2 times Was thanked: 46 time(s) in 32 post(s)
zenvideo wrote:atmonauti wrote:... and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment. The NDI SDK uses the CPU for its codec, so i9 will probably be best. Just for completeness, NDI *HX* decoding can use GPU if that is enabled by the host application. So if you are using a lot of NDI HX sources and hardware decode is enabled, then GPU will be useful. Everything else about NDI uses CPU only, as Martin explained.
 1 user thanked livepad for this useful post.
livepad wrote:zenvideo wrote:atmonauti wrote:... and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment. The NDI SDK uses the CPU for its codec, so i9 will probably be best. Just for completeness, NDI *HX* decoding can use GPU if that is enabled by the host application. So if you are using a lot of NDI HX sources and hardware decode is enabled, then GPU will be useful. Everything else about NDI uses CPU only, as Martin explained. Thank you for the information. Does either method introduce latency over the other? That is, hardware decoding via GPU vs CPU? I do happen to be using NDI-HX sources for the most part. I ask because I plan on building the Obsidian reference system either way, but which of the above is the better practice?
atmonauti wrote: Does either method introduce latency over the other? That is, hardware decoding via GPU vs CPU? I do happen to be using NDI-HX sources for the most part.
Latency has nothing to do with CPU or GPU in this case. NDI|HX is a LongGOP style compression and all LongGOP style compression codecs will have some latency. That being said, NDI|HX is probably the lowest latency you will find for this kind of compression, but it will be a few frames. NDI will be 1 frame of latency in software, in a hardware version it can be down to few video lines of latency. Kane Peterson NewTek
NDI
