atmonauti
#1 Posted : Tuesday, March 13, 2018 12:08:42 PM(UTC)
atmonauti
Hi all,
I'm looking into building a new system specifically for running vMix. We use 4 or more NDI inputs per shoot, and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment.
Thanks.
zenvideo
#2 Posted : Tuesday, March 13, 2018 2:57:59 PM(UTC)
zenvideo
atmonauti wrote:
... and was wondering which is used more for NDI; CPU or GPU? I plan on putting a 1080 TI in there no matter what, but I'm contemplating an i7 vs an i9 at the moment.
The NDI SDK uses the CPU for its codec, so i9 will probably be best.
livepad
#3 Posted : Thursday, March 15, 2018 10:06:08 AM(UTC)
livepad
Was thanked: 46 time(s) in 32 post(s)
Just for completeness, NDI *HX* decoding can use GPU if that is enabled by the host application. So if you are using a lot of NDI HX sources and hardware decode is enabled, then GPU will be useful. Everything else about NDI uses CPU only, as Martin explained.
thanks 1 user thanked livepad for this useful post.
atmonauti on 3/15/2018(UTC)
atmonauti
#4 Posted : Thursday, March 15, 2018 11:35:43 AM(UTC)
atmonauti
Thank you for the information.
Does either method introduce latency over the other? That is, hardware decoding via GPU vs CPU? I do happen to be using NDI-HX sources for the most part.
I ask because I plan on building the Obsidian reference system either way, but which of the above is the better practice?
kane
#5 Posted : Thursday, March 15, 2018 4:32:23 PM(UTC)
kane
Latency has nothing to do with CPU or GPU in this case. NDI|HX is a LongGOP style compression and all LongGOP style compression codecs will have some latency. That being said, NDI|HX is probably the lowest latency you will find for this kind of compression, but it will be a few frames.
NDI will be 1 frame of latency in software, in a hardware version it can be down to few video lines of latency.
Kane Peterson
NewTek
