Overlay Input fades in instead of Cutting In.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hello Everyone, I have a shortcut that causes an overlay of an image to appear. I want the image to CUT in. However it is fading in. Attached is a link to a short screen share that shows the results, as well as the Shortcut settings. The image that I am trying to CUT in is called "Yellow Shield" I am using "On transitionIn" and "OverlayInput3" I don't see a place to change the FADE IN to a CUT IN. https://www.screencast.com/t/t9sL7Id7cThanks, Rowby
Change the duration time, or use CUT rather than FADE........check and see what happens
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Thanks! The more I use vMix the more I learn. Here's some of the many options available when you click on the overlay button. You select the overlay and select what you want. You apparently can even include a stinger instead of a standard transition via this panel. Rowby rowby attached the following image(s):  overlay-settings.png (75kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
