rowby
#1 Posted : Saturday, March 10, 2018 1:45:50 PM(UTC)
rowby
Hello Everyone,
I have a shortcut that causes an overlay of an image to appear.
I want the image to CUT in. However it is fading in.
Attached is a link to a short screen share that shows the results, as well as the Shortcut settings.
The image that I am trying to CUT in is called "Yellow Shield" I am using "On transitionIn" and "OverlayInput3"
I don't see a place to change the FADE IN to a CUT IN.
https://www.screencast.com/t/t9sL7Id7c
Thanks,
Rowby
Joeboe
#2 Posted : Saturday, March 10, 2018 2:16:44 PM(UTC)
Joeboe
Change the duration time, or use CUT rather than FADE........check and see what happens
richardgatarski
#3 Posted : Saturday, March 10, 2018 3:07:40 PM(UTC)
richardgatarski
In the Overlay settings for Overlay3 change from Fade to Cut
https://www.vmix.com/help20/Overlay2.html
rowby
#4 Posted : Saturday, March 10, 2018 6:15:32 PM(UTC)
rowby
Thanks!
The more I use vMix the more I learn.
Here's some of the many options available when you click on the overlay button. You select the overlay and select what you want. You apparently can even include a stinger instead of a standard transition via this panel.
Rowby
rowby attached the following image(s):
