taurojo
#1 Posted : Saturday, March 3, 2018 4:59:10 AM(UTC)
taurojo
Need to know what is the play time of a video.
Especially if it's on the program.
Is it possible?!!
Thanks for your time.
#2 Posted : Saturday, March 3, 2018 5:20:51 AM(UTC)
how about under the output when playing ?
doggy attached the following image(s):
stigaard on 3/4/2018(UTC)
taurojo
#3 Posted : Saturday, March 3, 2018 9:53:30 AM(UTC)
taurojo
Of course!!!!
The question is whether the player's time can be captured in the API. Not in the software.
I nned get the time player for controler the real play in program or fonts.
DYosua
#4 Posted : Saturday, March 3, 2018 5:19:09 PM(UTC)
DYosua
Was thanked: 15 time(s) in 12 post(s)
You can use http://localhost:8088/API which will bring back XML from the inputs. Each input containing a video/audio file, will have an attribute called "position" which is the current position of the playhead (in milliseconds). There is also a duration called "duration" which is the length of the file in milliseconds.
The XML also contains an attribute called "active" which gives the input number currently on the program monitor.
#5 Posted : Saturday, March 3, 2018 7:44:05 PM(UTC)
2 different questions, twice correct response ;-)
