Need to know what is the play time of a video. Especially if it's on the program. Is it possible?!!
Thanks for your time.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
how about under the output when playing ? doggy attached the following image(s):  playtime.JPG (18kb) downloaded 7 time(s).You cannot view/download attachments. Try to login or register.
Of course!!!!
The question is whether the player's time can be captured in the API. Not in the software. I nned get the time player for controler the real play in program or fonts.
Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 15 time(s) in 12 post(s)
You can use http://localhost:8088/API which will bring back XML from the inputs. Each input containing a video/audio file, will have an attribute called "position" which is the current position of the playhead (in milliseconds). There is also a duration called "duration" which is the length of the file in milliseconds.
The XML also contains an attribute called "active" which gives the input number currently on the program monitor.
2 different questions, twice correct response ;-)
