How To Schedule Streaming Automatically?
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
I’ve looked around a fair bit on this topic, and am fairly convinced there is no real answer to this, but could I just ask the forum…
Is it possible to schedule streaming (and recording) to start automatically, at a specific time?
Facebook Live permits this feature, and it would be terrific if it’s possible to hook the other end up with VMix.
Thanks!
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
 1 user thanked Cpilcher for this useful post.
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
 1 user thanked pm for this useful post.
 1 user thanked kjones9999 for this useful post.
This is how to Automatically Schedule a stream without buying any software. All Naturally through Windows. 1.Search for Task Scheduler in windows 2.Select on right side, create basic task 3.Name your task. Ex: Vmix Stream Schedule. Click Next. 4.Select the frequency of your stream. I personally do a weekly broadcast at my church. Click next then set the repeat frequency. Click Next again. 5.Under Action, the "Start a Program" radio button will be selected.. Click Next. 6.In the Program/Script text field, (Assuming you are using Chrome as a browser) enter: C:\Program Files\Google\Chrome\Application\chrome.exe. In the Add Arguments text field enter : http://127.0.0.1:8088/api/?Function=StartStreaming&Duration=1000 Click Next. On the last screen, Press Finish. You can find your Task in the list and force run to test it.
 1 user thanked matt@gvchurch.tv for this useful post.
