AgentPete
#1 Posted : Tuesday, February 27, 2018 12:49:02 PM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
I’ve looked around a fair bit on this topic, and am fairly convinced there is no real answer to this, but could I just ask the forum…
Is it possible to schedule streaming (and recording) to start automatically, at a specific time?
Facebook Live permits this feature, and it would be terrific if it’s possible to hook the other end up with VMix.
Thanks!
Cpilcher
#2 Posted : Tuesday, February 27, 2018 4:27:59 PM(UTC)
Cpilcher
I believe I have seen an updated to the vTask software. It is a 3rd party solution that can do what you want.
https://forums.vmix.com/...aspx?g=posts&t=11608
thanks 1 user thanked Cpilcher for this useful post.
AgentPete on 3/4/2018(UTC)
pm
#3 Posted : Tuesday, February 27, 2018 4:38:48 PM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
One idea is to create a scheduled task on your vMix computer and execute an API command to start recording or streaming.
https://www.technig.com/windows-10-task-scheduler/
https://www.vmix.com/hel...utFunctionReference.html
https://www.vmix.com/help20/DeveloperAPI.html
Patrick
thanks 1 user thanked pm for this useful post.
kjones9999
#4 Posted : Thursday, March 1, 2018 12:20:32 AM(UTC)
kjones9999
These are good solutions. I created a piece of software that will do this as well.
https://forums.vmix.com/...aspx?g=posts&t=14302
thanks 1 user thanked kjones9999 for this useful post.
matt@gvchurch.tv
#5 Posted : Wednesday, November 30, 2022 2:16:09 AM(UTC)
matt@gvchurch.tv
This is how to Automatically Schedule a stream without buying any software. All Naturally through Windows.
1.Search for Task Scheduler in windows
2.Select on right side, create basic task
3.Name your task. Ex: Vmix Stream Schedule. Click Next.
4.Select the frequency of your stream. I personally do a weekly broadcast at my church. Click next then set the repeat frequency. Click Next again.
5.Under Action, the "Start a Program" radio button will be selected.. Click Next.
6.In the Program/Script text field, (Assuming you are using Chrome as a browser) enter: C:\Program Files\Google\Chrome\Application\chrome.exe. In the Add Arguments text field enter :http://127.0.0.1:8088/api/?Function=StartStreaming&Duration=1000 Click Next.
On the last screen, Press Finish.
You can find your Task in the list and force run to test it.
thanks 1 user thanked matt@gvchurch.tv for this useful post.
nikosman88 on 11/30/2022(UTC)
Guest (4)
