Duff TV
#1 Posted : Monday, February 26, 2018 9:13:57 PM(UTC)
Duff TV
Having trouble with the external output in vMix and can't get the outputs to an external source working using the Blackmagic Quad (the original Quad).
Card: Blackmagic Quad (with the latest drivers installed)
vMix version: 20.0.0.55 (Pro Version)
Outputting 720 50p
I have attached screen shots to show you the settings I have tried in vMix.
Is there any specific setup required in the Blackmagic software (Desktop Video Setup) that need to be configured first?
I also have a Blackmagic Duo in my PC and the external output works fine in vMix.
Any help or advice would be appreciated
Kind Regards,
Duff TV attached the following image(s):
External Settings.JPG (59kb) downloaded 1 time(s).
vMix Error.JPG (41kb) downloaded 1 time(s).
corporatejames
#2 Posted : Monday, February 26, 2018 9:25:45 PM(UTC)
corporatejames
Did you try setting the output options in Blackmagic Desktop Video app (selecting the channel for Output and the resolution)
FYI I dont have issue with the Duo2 either after choosing switch channel for Output.
#3 Posted : Monday, February 26, 2018 9:51:37 PM(UTC)
Was thanked: 4643 time(s) in 1604 post(s)
Are you using port 4 anywhere else as an input in vMix?
Note that the original quad is 4 channel only, which means only 4 inputs can be used or 3 inputs and 1 output.
Similar Topics
vMix 17 Decklink External Output issues -Fixed (General Discussion)
by admin 5/25/2016 11:00:48 PM(UTC)
External Output issues (Tested: 9.1.0.33-34) (General Discussion)
by jet 6/12/2013 12:57:25 PM(UTC)
