Hi, Having trouble with the external output in vMix and can't get the outputs to an external source working using the Blackmagic Quad (the original Quad). Card: Blackmagic Quad (with the latest drivers installed) vMix version: 20.0.0.55 (Pro Version) Outputting 720 50p I have attached screen shots to show you the settings I have tried in vMix. Is there any specific setup required in the Blackmagic software (Desktop Video Setup) that need to be configured first? I also have a Blackmagic Duo in my PC and the external output works fine in vMix. Any help or advice would be appreciated Kind Regards, Martin Duff TV attached the following image(s):  External Settings.JPG (59kb) downloaded 1 time(s). vMix Error.JPG (41kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Did you try setting the output options in Blackmagic Desktop Video app (selecting the channel for Output and the resolution) FYI I dont have issue with the Duo2 either after choosing switch channel for Output.
Joined: 1/13/2010(UTC) Posts: 5,324  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Are you using port 4 anywhere else as an input in vMix? Note that the original quad is 4 channel only, which means only 4 inputs can be used or 3 inputs and 1 output.
