NHT
#1 Posted: : Monday, March 13, 2017 12:49:56 PM(UTC)
NHT
Guys have you got recommendations for cheap camcorders with LANC control?
Cheap as possible as long as they're 1080, any suggestions greatly appreciated.
#2 Posted : Monday, March 13, 2017 1:07:37 PM(UTC)
Hi
I recommend Canon HF G series. The models with DIGIC3 image processor are under $800 with pretty good results. DIGIC4 models (HF G30/40) are slightly above $1000 and worth it.
Guillaume
NHT on 3/13/2017(UTC)
SportsNetUSA.net
#3 Posted : Monday, March 13, 2017 1:59:38 PM(UTC)
SportsNetUSA.net
Also the Sony HDR CX380 works with LANC and does 1080p. It would need a Sony VMC-AVM1 Multiport Adapter ($20-$29) and a breakout cable for the LANC. I've used one and it works with LANC. You can still find the CX380 on eBay.
DWAM suggestion of a Canon HF G series is a solid choice. Found a nice HF G30 that works well.
thanks 1 user thanked SportsNetUSA.net for this useful post.
stigaard
#4 Posted : Monday, March 13, 2017 6:58:29 PM(UTC)
stigaard
Denmark
I can also highly recommend Canon HF G30. Bought two of those, and use them extensively each with a cheap LANC controller, and it works really great.
Sample videos from our productions using Canon HF G30 can be found at:
https://www.youtube.com/user/bfcfloorball
https://www.youtube.com/user/HFTish
Peter B
#5 Posted : Tuesday, March 14, 2017 9:45:56 AM(UTC)
Peter B
Does Lanc support iris? I saw it on a Lanc protocol sheet years ago but haven't seen a camera that does.
#6 Posted : Tuesday, March 14, 2017 10:02:37 AM(UTC)
Yes it potentially does but LANC implementation is not always complete on cameras and I never found a LANC controller which allows iris control. Usually they have zoom and focus controls.
An alternative to LANC is to use Wifi for iris. On Canons/Sonys it works very well.
LANC protocol reference.
http://www.boehmel.de/lanc.htm
Ario on 5/30/2019(UTC)
Cormac
#7 Posted : Tuesday, March 14, 2017 2:39:39 PM(UTC)
Cormac
Hi i know that on Panasonic c920 camcorders which are kind of the equivalent of the canon g25 that the wifi control does not work when you have a hdmi out feed . Is this the same with the Sonys?
Cheers cormac
#8 Posted : Tuesday, March 14, 2017 2:44:23 PM(UTC)
Can't tell for all Sony models, but with a7s and RX10, it's working pretty well
Also working with Canon HF G30.
Canon HF G25 has no Wifi support.
Cormac
#9 Posted : Tuesday, March 14, 2017 3:33:09 PM(UTC)
Cormac
Hi I'm wondering more about the camcorder models ?
HWL1223
#10 Posted : Monday, March 20, 2017 12:34:46 PM(UTC)
HWL1223
FWIW - My Canon G10 died and Canon has no refurbed 30's, https://shop.usa.canon.c...shed-consumer-camcorders
I called them on their Customer Loyalty number 866-443-8002 and they are selling me a new G40 for $935 - cheapest price I have seen.
slb5146
#11 Posted : Wednesday, February 21, 2018 5:17:30 PM(UTC)
slb5146
Can someone help me with a link to a Lanc adapter that will work on canon video cameras? I found this for Sony On Amazon.
Kelvin
#12 Posted : Wednesday, February 21, 2018 5:47:41 PM(UTC)
Kelvin
Most Canons that I am aware of use the original 2.5mm Lanc cable directly and don't require an adapter. Newer Sony's on the otherhand may need a 2.5mm to AVR cable and then an AVR - multiport cable (the one on the Amazon link).
SportsNetUSA.net
#13 Posted : Wednesday, February 21, 2018 5:51:56 PM(UTC)
SportsNetUSA.net
Kelvin is spot on. Go to Amazon and do a search for LANC controller. I use Libec controllers they work well. And also ProZoom models from Studio1 Productions. No problems with either brand.
https://www.studio1productions.c...zoom-controller-menu.htm
Kelvin
#14 Posted : Wednesday, February 21, 2018 6:04:17 PM(UTC)
Kelvin
Also note that many of the newer Sony consumer models (after about 2014 or so) dont support Lanc in any form. For example, the FDR-AX100 supports Lanc, but the newer AX33 and AX53 don't.
elvis55
#15 Posted : Thursday, February 22, 2018 3:31:48 AM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
