2 Pages<12
cgarwood
#21 Posted : Friday, September 22, 2017 1:54:25 PM(UTC)
cgarwood
Was thanked: 8 time(s) in 3 post(s)
Also interested in seeing if there have been any updates on this. The StreamDeck would be perfect for our setup.
BETech
#22 Posted : Monday, September 25, 2017 9:21:49 PM(UTC)
BETech
The StreamDeck is a great concept, though it does not work well with vMix. VMix does not support the Modifier keys at the moment, so ALT Ctrl and Shift for the StreamDeck are out of the question. Unlike the reliable ASCii keyboard interfacing to vMix, the StreamDeck sometimes will trigger both on the KeyDown & KeyUp command, thereby double actioning the command to switch. Also, AutoRepeat may a problem if the User holds the button down to long, as this cannot be disabled in their software. Even when using the ASCii2Midi software application, with the KeyUp event and AutoRepeat disabled at the low level interrupt level, the StreamDeck reset those LL_Keyboard requests when the application started. Shame really, as the StreamDeck has a lot of promise. Some thoughts for consideration.
lael
#23 Posted : Tuesday, December 5, 2017 7:47:11 PM(UTC)
lael
Does anyone have the streamdeck working properly in vMix?
natep
#24 Posted : Wednesday, December 20, 2017 7:40:47 PM(UTC)
natep
Was thanked: 3 time(s) in 1 post(s)
I also can't wait to see what these guys do with their driver/interface. In the meantime, I did a simple one if anyone wants to check it out. I am not a programmer, so the code is ugly and you can't customize it or anything yet (unless you want to change the icons or modify the code). I actually just used the basic design that Sondrey had posted because I liked the way it looked.
https://github.com/npowless/StreamDeckVMix
natep attached the following image(s):
Rogue_Danar
#25 Posted : Saturday, December 30, 2017 11:59:30 PM(UTC)
Rogue_Danar
Any updates on this? I'd love to see this fully functional with vMix!
vmixsupport
#26 Posted : Sunday, December 31, 2017 12:56:34 AM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 160 time(s) in 73 post(s)
They've said that they may be working on an SDK, but it's going to be a while if it ever happens.
Dune
#27 Posted : Sunday, January 14, 2018 12:30:26 AM(UTC)
Dune
I am currently using Stream Deck with vMix and it works well, it does have some limitations, but is still great in my opinion. You can set some crazy complacated as well as very simple shortcuts in vMix and then use the Hotkey and Hotkey Switch option to map them on the Stream Deck. Its not very difficult to set up and so far it has been a big help for me to control everything without having to use the trackpad (mouse) The one thing that can be an issue is if you use the PC for another tasks that take you off of the vMix app none of the commands will work (no different than keyboard shortcuts that are used) For the many spent on the vMix program the $150 was well worth the price.
Dune attached the following image(s):
lael
#28 Posted : Tuesday, February 6, 2018 8:29:35 AM(UTC)
lael
Would you mind doing a video showing some of your setup working and what you did to make it work?
thanks 1 user thanked lael for this useful post.
Dynamic8 on 2/8/2018(UTC)
richardgatarski
#29 Posted : Tuesday, February 6, 2018 2:15:30 PM(UTC)
richardgatarski
Dune wrote:
...The one thing that can be an issue is if you use the PC for another tasks that take you off of the vMix app none of the commands will work (no different than keyboard shortcuts that are used)....
Check out my Feature Request for Application Global Shortcuts and consider if you think it's worth a +1.
Barney Box Lane
#30 Posted : Wednesday, February 7, 2018 7:48:40 AM(UTC)
Barney Box Lane
streamdeck is awesome and you can now control one device with 2 or more boxes if you have the so are usb ports
dungthantai
#31 Posted : Monday, February 19, 2018 4:39:40 AM(UTC)
dungthantai
The control board is modding by myself
It working great
You can see more in here
https://www.facebook.com...eo_source=user_video_tab
I just do it for myself and some of my customer, can I sell it on Amazon or Ebay ? is that possible ?
tlaurencin
#32 Posted: : Thursday, February 22, 2018 5:59:22 AM(UTC)
tlaurencin
Sondrey wrote:
Hey guys!
We have recieved this device and have been able to program a vMix "driver" for it :)
This "driver" will be able to show animations and timers etc. on the button screens.
Updates coming soon!
Hi Sondrey,
could you advance on the configuration of the interface because not easy i'm not a programer !
I try with Bome's midi translator, but no result...
Thank you so much
thierry
hidavid
#33 Posted : Tuesday, May 29, 2018 2:17:15 PM(UTC)
hidavid
Sondrey wrote:
Hey guys!
a good year later: is there any chance to use / buy this software? It would infinitely improve the Stream Deck over the simple Switching it provides out of the box.
2 Pages<12
