jaialai
#1 Posted : Thursday, February 15, 2018 1:53:51 PM(UTC)
jaialai
Hi, this is my firs topic. My english it's very bad, sorry.
I have VMix HD and I would like to do the following operation.
I have to insert several logos during a concert (all time must be a logo in the screen). I have used the following sequence:
- ADD INPUT + PHOTOS + select FOLDER LOGOS + in the timeline right button of the mouse and select SLIDE SHOW SETTINGS. in the TRANSITION box can insert the time that I want.
My question or problem that if a insert a time (for examble 90 seconds) all logos change each 90 seconds AND I WANT INSERT DIFFERENTS TIMES to each logo.
I hope that your can understand what i mean.
Thanks beforehand.
Pedro
#2 Posted : Thursday, February 15, 2018 2:17:25 PM(UTC)
HI
You can use scripts to do this if you have 4K or Pro version.
Otherwise you can use anything that can send commands to the API.
I could do it with vMix UTC too
https://forums.vmix.com/....aspx?g=posts&t=6468
Guillaume
#3 Posted : Thursday, February 15, 2018 2:39:58 PM(UTC)
could you not have the same logo multiple times to combine time ?
Say logo 1 is 10 seconds,logo 2 is 20 (2xlogo for 10 each ) etc ?
#4 Posted : Thursday, February 15, 2018 3:34:15 PM(UTC)
Smart way to do it Doggy
Another option is to create the sequence as a video with alpha transparency
jaialai
#5 Posted : Thursday, February 15, 2018 4:14:17 PM(UTC)
jaialai
Doggy could you explain step by step your solution?
I'm newer with vmix and my english puff
thanks
spencerm24
#6 Posted : Thursday, February 15, 2018 4:26:09 PM(UTC)
spencerm24
if i understand correctly, I think this could be done with a playlist, each item in a playlist can have its own duration.
#7 Posted : Thursday, February 15, 2018 4:36:18 PM(UTC)
@ jaialai,
You are already doing it , just have multiple copies of the same images in the folder which have to be displayed longer
Mari
#8 Posted : Thursday, February 15, 2018 5:08:30 PM(UTC)
Mari
Netherlands
as doggy said, just create another copy of the logo...
logo1, logo2, logo3, logo4, logo4copy, logo5
With a slideshow of 10 seconds it will show logo3 for 10 seconds and logo4(+logo4copy) for 20 seconds...
See logos at left-bottom corner of the screen, second logo changes twice as fast as the first logo
jaialai
#9 Posted : Thursday, February 15, 2018 6:35:37 PM(UTC)
jaialai
Oh yeah, now i understand. Tomorrow i test it. The solution was in front to my face.
jaialai
#10 Posted : Friday, February 16, 2018 5:31:49 AM(UTC)
jaialai
Yes, works great Doggy and DWAM.
Thanks.
