How to insert logos automatically with different time intervals
Hi, this is my firs topic. My english it's very bad, sorry.
I have VMix HD and I would like to do the following operation.
I have to insert several logos during a concert (all time must be a logo in the screen). I have used the following sequence:
- ADD INPUT + PHOTOS + select FOLDER LOGOS + in the timeline right button of the mouse and select SLIDE SHOW SETTINGS. in the TRANSITION box can insert the time that I want.
My question or problem that if a insert a time (for examble 90 seconds) all logos change each 90 seconds AND I WANT INSERT DIFFERENTS TIMES to each logo.
I hope that your can understand what i mean.
Thanks beforehand.
Pedro
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
could you not have the same logo multiple times to combine time ? Say logo 1 is 10 seconds,logo 2 is 20 (2xlogo for 10 each ) etc ?
Smart way to do it Doggy
Another option is to create the sequence as a video with alpha transparency
Doggy could you explain step by step your solution?
I'm newer with vmix and my english puff
thanks
if i understand correctly, I think this could be done with a playlist, each item in a playlist can have its own duration.
@ jaialai,
You are already doing it , just have multiple copies of the same images in the folder which have to be displayed longer
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
as doggy said, just create another copy of the logo... logo1, logo2, logo3, logo4, logo4copy, logo5 With a slideshow of 10 seconds it will show logo3 for 10 seconds and logo4(+logo4copy) for 20 seconds... See logos at left-bottom corner of the screen, second logo changes twice as fast as the first logo
Oh yeah, now i understand. Tomorrow i test it. The solution was in front to my face. Thanks
Yes, works great Doggy and DWAM.
Thanks.
