VLC Stream Input , Wrong image scale issue
Hello everyone, Just a short topic to report a weird bug with the new VLC Stream Input. When I load a RTMP or HTTP stream, the bottom screen of the input will be cropped a little bit. I upload a example screenshot, on the left a "browser source" with the correct resolution on the right a HTTP stream read by VLC with the "missing lines" on the bottom https://tof.cx/images/2017/12/10/31dd1cee2c11e0dc8a50b78396604538.pngI tried several VLC argument like :fullscreen , :autoscale, :no-autoscale but with no sucess.. Maybe anyone has the correct syntax for the vlc command line ? I mean inside vMix off course. Anyway, please could you correct this aspect ratio issue ? Thanks Best regards. Kaf
Joined: 11/5/2016(UTC) Posts: 29  Location: Paris Thanks: 7 times Was thanked: 4 time(s) in 4 post(s)
I have the same problem on 2 different Vmix Setup. It would be very nice to have the full size input please :) Cheers Valentin
Up ! Just tested with the new version still the same,
VLC RTMP crop the bottom video !
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
I think it's an issue with the headers of the feed. I use VLC input a lot with several encoders, never got a cropped image.
Does VLC play this stream correctly when used directly (not through vMix) ? Did you try another player than VLC?
Guillaume
Thanks for answer DWAM.
The Video source is encoded by OBS and send to a NGINX RTMP server.
The result are :
VLC (not vMix) = OK vMix RTMP INPUT (flash) = OK vMix VLC Input = Cropped image
I think we need a update of the VLC for vMix since VLC get the 3.0 new version. Maybe this update will fix the crop issue & more...
