Kaf
#1 Posted : Monday, December 11, 2017 10:50:13 AM(UTC)
Kaf
Hello everyone,
Just a short topic to report a weird bug with the new VLC Stream Input.
When I load a RTMP or HTTP stream, the bottom screen of the input will be cropped a little bit.
I upload a example screenshot, on the left a "browser source" with the correct resolution on the right a HTTP stream read by VLC with the "missing lines" on the bottom
https://tof.cx/images/2017/12/10/31dd1cee2c11e0dc8a50b78396604538.png
I tried several VLC argument like :fullscreen , :autoscale, :no-autoscale but with no sucess.. Maybe anyone has the correct syntax for the vlc command line ? I mean inside vMix off course.
Anyway, please could you correct this aspect ratio issue ?
Best regards.
Kaf
Yamato
#2 Posted : Friday, December 15, 2017 2:52:29 PM(UTC)
Yamato
I have the same problem on 2 different Vmix Setup.
It would be very nice to have the full size input please :)
Cheers
Valentin
Kaf
#3 Posted : Thursday, February 15, 2018 9:53:07 AM(UTC)
Kaf
Up ! Just tested with the new version still the same,
VLC RTMP crop the bottom video !
#4 Posted : Thursday, February 15, 2018 1:49:58 PM(UTC)
Was thanked: 795 time(s) in 589 post(s)
I think it's an issue with the headers of the feed.
I use VLC input a lot with several encoders, never got a cropped image.
Does VLC play this stream correctly when used directly (not through vMix) ?
Did you try another player than VLC?
Guillaume
Kaf
#5 Posted : Saturday, March 3, 2018 6:50:30 AM(UTC)
Kaf
Thanks for answer DWAM.
The Video source is encoded by OBS and send to a NGINX RTMP server.
The result are :
VLC (not vMix) = OK
vMix RTMP INPUT (flash) = OK
vMix VLC Input = Cropped image
Kaf
#6 Posted : Saturday, August 18, 2018 10:11:06 AM(UTC)
Kaf
I think we need a update of the VLC for vMix since VLC get the 3.0 new version.
Maybe this update will fix the crop issue & more...
