Argo82
#1 Posted : Monday, February 12, 2018 12:40:47 PM(UTC)
Argo82
Was thanked: 7 time(s) in 5 post(s)
Hi Everyone,
I am setting up a spreadsheet for team rosters and stats for a lower third. Right now my excel file has columns for:
Player #
Player First name
Player Last Name
Home City
Home State/Province
Is there a way to combine the "Player #, Player First Name, Player Last name" in one text field, and combine "Home City, Home State/Province" data in a second text field on the same title, or would I have to make a text field for each bit of data? I was a bit curious if the "Format" field (set at {0}) could do this in some way, but I've only managed to change the position of the text with that.
#2 Posted : Monday, February 12, 2018 12:54:12 PM(UTC)
As far as i know it is not possible to combine with the format field but:
as you are setting up a spreadsheet yourself you could either combine the desired fields during creation or if the data needs to stay seperated for some reason you could add a collumn with a formula that combines multiple cells and choose that colum for displau in your title
other option is let the title combine the data but is a bit more elaborate to prepare ( hidden fields that are combined to be displayed in the wanted text field ) by means of codebehind of the title
been discussed here too : https://forums.vmix.com/default.aspx?g=posts&t=11522
we often receive spreadsheets or lists with data seperated dispite having asked to have them combined , so a quick combine column makes the later use to our desire practical and quicker rather than trying to let them change the source
Argo82 on 2/12/2018(UTC)
Argo82
#3 Posted : Monday, February 12, 2018 1:09:19 PM(UTC)
Argo82
Sorry for the double post. It looks like something similar was already discussed like you mentioned.
I could combine some columns, but would rather keep some of them seperated, such as player number. I never thought of a combining formula in the spreadsheet though. Sounds like a great idea.
Thanks very much
#4 Posted : Monday, February 12, 2018 1:29:22 PM(UTC)
excel CONCATENATE function :-)
Argo82
#5 Posted : Monday, February 12, 2018 1:38:02 PM(UTC)
Argo82
Yup. Did the trick.
Thanks again.
