3rd Party Software and Development
Interpretation of errors when uploading XAML into vMix
Hello everyone! I have a bunch of XAML overlay. And I can open all of them in Microsoft Blend. They all perfect animated. It's cool. But when I trying to open XAML in vMix it appears error message like "The tag "EasingDoubleKeyFrame" does not exist in the XML namespace "http://schemas.microsoft.com/winfx/2006/xaml/presentation" line "5", position 10" Another teg is "UseLayoutRounding" with the same error.
What does this error says and with why should I start to find for the solution to this problem?
Thanks for the answer
vMix only allow a limited range of animation types. EasingDoubleKeyFrame is not one of them. I regularly use DoubleKeyFrame.
 1 user thanked stigaard for this useful post.
stigaard wrote:vMix only allow a limited range of animation types. EasingDoubleKeyFrame is not one of them. I regularly use DoubleKeyFrame. Tanks a lot. Where I can find the list of support animation types? P.S. I do not even quite understand exactly which animation this command prescribes and how can EasingDoubleKeyFrame be replaced with a DoubleKeyFrame, if this is possible in principle. Yesterday I tried EasingDoubleKeyFrame simply to delete, the error disappears, but the important part of the block for display also disappears.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
It has been a while since I designed my titles in blend, but I think you just right click on the key frame and you can select the desired type. It should change the look of the key frame symbol as well. I remember having a similar error because Blend defaults to an easing key frame if I recall correctly.
 1 user thanked Cpilcher for this useful post.
Cpilcher wrote:It has been a while since I designed my titles in blend, but I think you just right click on the key frame and you can select the desired type. It should change the look of the key frame symbol as well. I remember having a similar error because Blend defaults to an easing key frame if I recall correctly. I got fixed all I need. Thanks. Next step for me is find out all about "Storyboard", "EventTrigger" in XAML. How to control titles with many storyboards. Where I can read more about it? P.S. In my Blend the default key parameter is KeySpline <SplineDoubleKeyFrame/>
