scooby6335
#1 Posted : Saturday, February 3, 2018 3:06:00 AM(UTC)
scooby6335
Hello everyone!
I have a bunch of XAML overlay. And I can open all of them in Microsoft Blend. They all perfect animated. It's cool.
But when I trying to open XAML in vMix it appears error message like "The tag "EasingDoubleKeyFrame" does not exist in the XML namespace "http://schemas.microsoft.com/winfx/2006/xaml/presentation" line "5", position 10"
Another teg is "UseLayoutRounding" with the same error.
What does this error says and with why should I start to find for the solution to this problem?
Thanks for the answer
stigaard
#2 Posted : Saturday, February 3, 2018 4:17:18 AM(UTC)
stigaard
Denmark
vMix only allow a limited range of animation types. EasingDoubleKeyFrame is not one of them. I regularly use DoubleKeyFrame.
thanks 1 user thanked stigaard for this useful post.
scooby6335 on 2/3/2018(UTC)
scooby6335
#3 Posted : Saturday, February 3, 2018 5:50:09 AM(UTC)
scooby6335
Tanks a lot.
Where I can find the list of support animation types?
P.S. I do not even quite understand exactly which animation this command prescribes and how can EasingDoubleKeyFrame be replaced with a DoubleKeyFrame, if this is possible in principle. Yesterday I tried EasingDoubleKeyFrame simply to delete, the error disappears, but the important part of the block for display also disappears.
Cpilcher
#4 Posted : Saturday, February 3, 2018 10:30:35 AM(UTC)
Cpilcher
It has been a while since I designed my titles in blend, but I think you just right click on the key frame and you can select the desired type. It should change the look of the key frame symbol as well. I remember having a similar error because Blend defaults to an easing key frame if I recall correctly.
thanks 1 user thanked Cpilcher for this useful post.
scooby6335
#5 Posted : Saturday, February 3, 2018 4:03:15 PM(UTC)
scooby6335
I got fixed all I need. Thanks. Next step for me is find out all about "Storyboard", "EventTrigger" in XAML. How to control titles with many storyboards. Where I can read more about it?
P.S. In my Blend the default key parameter is KeySpline <SplineDoubleKeyFrame/>
