spencerm24
#1 Posted : Tuesday, January 23, 2018 4:59:53 PM(UTC)
spencerm24
Often External 2 is used for showing dedicated video for a projector screen in a conference while having different video from the main output, such as a sponsor loop, etc. Having them cut all the time is kinda annoying and distracting, I'd like to see an option for a simple dissolve transition on external 2 to make it visually appealing.
Peter B
#2 Posted : Wednesday, January 24, 2018 7:05:18 PM(UTC)
Peter B
Having a mix function on the layers in a multiview would allow this using a full screen layer as well as building up the comp layer by layer with a series of dissolves.
There's already the cut function ie the tickbox.
spencerm24
#3 Posted : Thursday, February 1, 2018 5:48:22 PM(UTC)
spencerm24
It might but it would have to be preset would it not? I wouldn't be able to fade to a shot on the fly in external 2 this way if I understand you right.
Peter B
#4 Posted : Thursday, February 1, 2018 7:10:16 PM(UTC)
Peter B
The input / multi-view could be sent directly to Ext2 and then it would behave like a traditional M/E with mix/cut options on each layer.
Each layer within the input would have a mix function.
spencerm24
#5 Posted : Friday, February 2, 2018 5:37:32 PM(UTC)
spencerm24
I'm playing around trying to figure out how that would work, I can get inputs on multiview to toggle on or off, so I'm halfway there, but getting it to fade is where I'm running into a challenge.
Peter B
#6 Posted : Friday, February 2, 2018 9:28:58 PM(UTC)
Peter B
The fade function is the feature request.
spencerm24
#7 Posted : Saturday, February 3, 2018 3:24:13 PM(UTC)
spencerm24
Gotcha, I misunderstood!
Ittaidv
#8 Posted : Saturday, February 10, 2018 2:14:47 PM(UTC)
Ittaidv
+1
Peter B
#9 Posted : Saturday, February 10, 2018 7:49:49 PM(UTC)
Peter B
An idea from Horbel in this allied thread -
`A trick to fake transitions would be to live control the pan/tilt/zoom/crop/ opacity functions of the inputs through API / scripts.'
https://forums.vmix.com/...aspx?g=posts&t=13967
